just got some new pedals, i had on some v 8`s before and they had spacers between the pedal and the crank arm, these new ones don't have spacers, do i still use the ones from the v8? or shall i just screw the new ones straight into the arm? thx
Posted : 12/01/2010 4:47 pm
the spacers are likely to have come with the crank rather than the pedals so I'd probably stick with them if that's the case.
Posted : 12/01/2010 4:48 pm
ah right ok, they was already on in the shop so wasent sure
Posted : 12/01/2010 4:53 pm
nop u dont put the spacers on i tried, if you keep them on they stop the pedal from moving around, take them off and the pedal screws in leaving about a cm gap between that and the crank arm making it spin 🙂 thx anyway
Posted : 12/01/2010 5:04 pm
