Alternatives to spl...
[Closed] Alternatives to splined tool for fitting Hollowtech II cranks?
[#3754131]
Having dutifully gone out and bought the spanner to fit my H2 bottom bracket, I notice there's a splined plastic cap to finish the fitting of the LH crank.
Am I going to have to get my wallet out again for another tool or is there an alternative method of getting it nipped up?
Posted : 08/03/2012 4:06 pm
The park one comes with it on the other end.
the plastic ones don't cost much, and often come with cranksets, alloy ones are available also
Posted : 08/03/2012 4:08 pm
If you have the Park Tool BBT-9 it's the plastic bit on the other end of the tool:
http://www.parktool.com/product/bottom-bracket-tool-bbt-9
Otherwise you might get it out with a large flathead screwdriver, being careful. It's not tightly screwed in.
Posted : 08/03/2012 4:10 pm
A plastic tyre lever does the job OK
Posted : 08/03/2012 4:14 pm
 MSP
It only needs to be finger tight, over tightening probably causes more BB problems than facing/not facing the BB shell.
Posted : 08/03/2012 4:15 pm
 was
£1.49 delivered for the correct tool here:
http://www.tweekscycles.com/Search.do?method=delegate&n=3339&p=33901&s=tl-fc16
Posted : 08/03/2012 4:19 pm
 was
Or £6.95 delivered for the IceToolz tool that does both here:
http://www.ebay.co.uk/itm/250980492382
Posted : 08/03/2012 4:20 pm
Cheers all. Combination of being a skinflint and wanting to get out tomorrow on my shiny new cranks.
Posted : 08/03/2012 4:38 pm
As above, a tyre lever sometimes fits, or a chainring bolt spanner definately does.
Posted : 08/03/2012 4:43 pm
 IanW
I have used a flat blade file that happensto fit between two splines. Works perfect, you can file stuff with it too.
Anything that can turn it is fine.
Posted : 08/03/2012 6:23 pm
20p fits spot on.
Posted : 08/03/2012 6:39 pm
correct tool is only 20p
literally
(bah ! beaten again 🙁 )
Posted : 08/03/2012 6:41 pm
neilforrow - Member
20p fits spot on.
every day's a school day. I've had dozens and dozens of these on and off (with the tool) and never thought of that. Nice one 😀
Posted : 08/03/2012 6:46 pm
Its not like it has to be done up very tight anyway.
Posted : 08/03/2012 6:48 pm
All done now. Tyre lever did the trick. Wish I'd thought of the 20p.
Thanks to everyone who helped out.
Posted : 08/03/2012 7:27 pm
