Alternatives to Roa...
[Closed] Alternatives to Roadrat?
[#1675914]
Hi thinking of a new bike project. I want to do a bit of road, some light off road and mostly commuting/ riding on disused railway cycle trails (some long inclines so will need gears)/ canal tow paths on it. I want to run drops (most likely on one midge), and will be 700cc wheels with mostly cyclocrossish tyres. May also want to run cable discs in future.
At moment Cotic Roadrat seems to fit bill the best, but also looking at Surly Crosscheck (but can't use discs), Singular Peregrine would be nice but pricy alternative.
Would be using derailleur gears initailly, but may convert to Alfine once 11 speed hub comes out (if they ever sort a drop shifter).
Is it possible to use Cotic chain tugs on a Pompino inorder to run gears?
Any advise/ ideas appreciated
cheers
Posted : 05/06/2010 7:24 pm
Uncle john, kaff, pomp, all cheap, all good fun
Posted : 05/06/2010 7:42 pm
New On One Pompetamine?
Posted : 05/06/2010 8:36 pm
Pearson Hanzo?
Posted : 06/06/2010 9:07 am
I've used one of [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=249 ]these[/url] on my Pompino before to add gears... and it works just fine.
Posted : 06/06/2010 9:14 am
If Cross-check appeals but for the discs then the Surly Karate Monkey would do you perhaps. You see a fair few Monkey builds with midges and the like.
I don't use drops, but am running 42mm slicks on mine at the moment, which works very nicely.
Posted : 06/06/2010 9:22 am
I'm in a similar situation and looking at the Kinesis Tripster.
Posted : 06/06/2010 9:37 am
My experience - had a Cross-Check, fancied a Roadrat, bought one and built it up, hated the way it rode vs the Surly, sold the Roadrat, still got the Cross-Check and love it.
I thought the Roadrat gear/chaintug thing was horrible if you ever have to take the back wheel out. Oily chain and mech flopping about, it's a complete arse. Fine s/s or Alfined of course.
Posted : 06/06/2010 9:45 am
Kona Honky inc or Genesis Croix De Fer
Posted : 06/06/2010 10:40 am
 Andy
My solution for the same thing; built up yesterday morning, from some spare 29er bits and a frame off the classifieds.
Steerer tube is long as might run with drop bars.
Posted : 06/06/2010 10:41 am
Onzadog - Member
nice tip thanks in the description says suitable ‘[i]inboard’ mounted disc brake[/i] - what does that mean?
Posted : 06/06/2010 11:10 am
It means the mounts are on the chain stay rather than the seat stay to keep them away from the rack and guard mounts.
Posted : 06/06/2010 11:53 am
Onzadog - Member
thanks - kinesis website suggests Tektro Lyra's but reviews don't seem great - i guess there is no reason why Avid BB7's won't fit? I'd be running STI's so i guess thats about it choicewise?
also
PaulGillespie - Member
Kona Honky inc
am i right in thinking that kona's are only available as full builds?
Posted : 06/06/2010 12:11 pm
I emailed Dom at Kinesis and he sent me the drawing for the rear drop outs. I scaled that up and offered by the brake I was planning on using (Hope Enduro 4, number 3 caliper 165mm rotor with adaptors for drop levers). Glad I did that as my first choice, the number 5 caliper for the 145mm rotor isn't going to fit. However, it does look like there's plenty of space in there so it shouldn't be an issue. I'd be very surprised if the Avids didn't fit.
Posted : 06/06/2010 12:17 pm
thanks - i'd be surprised too but sounds like might be worth checking now i understand what "inboard" means
Posted : 06/06/2010 12:27 pm
