Almost time to get ...
Almost time to get Zwifty again... Turbo and pain cave content..show us yours!
I ride normal spd-sl road pedals when I commute on the bike but for some reason using those pedals or Shimano mtb xc style pedals and shoes ruin my right foot on the trainer. No idea why – but it messed up my right foot for ages. No issues when out on the road though.
Something similar happened to me during lockdown, when I was using the turbo every day - turned out I had the cleat slightly twisted, and while it didn't make any difference on the road I ended up with a dodgy knee. On road I'm guessing I move about a fair bit more, standing up, shifting on the saddle etc., and a slightly offset cleat isn't as important. Anyway these days I use some old Time Atacs which have a huge amount of float.
Posted : 20/09/2022 11:32 am
Yeah I don’t wish to repeat my foot pain which stopped me being able to run / hurt when I walked etc. I think I’m fairly good at spinning circles on flats rather then just mashing downwards - so will continue to do that on the turbo. I don’t expect to be especially fast at Zwift racing but it’s just to replace muddy night rides every week once the slop arrives. Going to do a ramp test tonight and start off another TrainerRoad block of training. Has got up to 250ish ftp and down to sub 75kgs but it slipped with a back spasm I had. Think I’m probably down to about 225ftp at a guess and up to 76.5kgs so I’ve got some work to do.
Posted : 20/09/2022 12:07 pm
I used to love Time atacs- the grey and green composite ones with just the bars on each side and nothing else fancy!
Posted : 20/09/2022 12:08 pm
My setup, back of the garage:
[url= https://i.postimg.cc/6q7h7g2t/1663668264015.jp g" target="_blank">https://i.postimg.cc/6q7h7g2t/1663668264015.jp g"/> [/img][/url]
HT on a Flux S. Started out with a laptop and WiFi and quickly upgraded to AppleTV, ethernet over powerline and the TV borrowed from the caravan. Two cheap fans from Argos plugged in to Alexa do the job well enough.
Only thing i'm not happy with - AppleTV remote is awful, any recommended replacements?
Posted : 20/09/2022 12:38 pm
AppleTV users - I've posted about this before, but does anyone else struggle with updates? Whenever an update is available, I click to download from the app store, but it just switches to a screen saying "coming soon." I always have to delete the app and reinstall it.
Posted : 20/09/2022 2:36 pm
ATV owner here - never had a problem. I have it apps to auto-update, and if I know an update is happening I turn it on a few mins early. If I'm short of time I will go to the app store, select Zwift explicitly and update from there.
I don't use the ATV for much else, and it is the 4K version, so there is little else on it - that might be a factor.
Which bit says 'coming soon' - the app store or zwift itself ?
Posted : 20/09/2022 2:52 pm
Yeah I never had an issue with updates on the apple TV, again I had apps set to auto update, it was always updated when I turned it on.
Of course, it tends to get stuff later than pc like the new home screen but that's another matter.
Posted : 20/09/2022 2:56 pm
No problems with AppleTV updates either. Auto updates on, it just does it.
Posted : 20/09/2022 3:01 pm
Quick Zwift question; I'm doing the Zwift Academy workouts but I struggle to keep the power in the right band, often wandering well above the target. Should I be using ERG mode for these? (I've never used ERG mode so don't really understand the difference).
Ta
Posted : 20/09/2022 3:45 pm
 DrP
YES!!!
ERG basically 'makes' you output the required power regardless of cadence...
Definitely use ERG for workouts!
DrP
Posted : 20/09/2022 3:49 pm
The Zwift academy baseline ride is a group ride though isn't it, not a proper workout. Are the rest of the 'workouts' the same or proper workouts?
If the latter, 100% use erg mode, and change into the small ring at the front with a gear that gives a straight chain line, the trainer well be quieter and will work better like this, as gears don't matter.
Posted : 20/09/2022 3:52 pm
After the Baseline ride, the rest are workouts.
I'll try ERG mode for the next one, ta.
Posted : 20/09/2022 3:54 pm
 DrP
oh yeah.. DON'T CHANGE GEAR IN ERG MODE!!!
DrP
Posted : 20/09/2022 4:04 pm
oh yeah.. DON’T CHANGE GEAR IN ERG MODE!!!
DrP
Unless you have to do micro 15 second intervals at 120rpm or something stupid where erg mode would mean you'd end up spinning away but with no resistance... 😁
But yeah, generally just let the trainer do the work!
Posted : 20/09/2022 4:06 pm
Yeah - baseline is a normal ride - so you feel the terrain as you would on a normal ride.
Chill through the non-times segments and then smash it on the timed bits.
Important thing is to carry on riding down the volcano after the last segment until the blue banner. I've seen quite a few people moaning about it on the forum, as they have quit the ride after the KOM banner at the top & have then lost the ride stats.
When doing the workouts - definitely ERG mode - and also use the inner ring (assuming you are on a 2x set-up) and aim for somewhere around the middle of the cassette. I think I generally run on the 4th cog from biggest (on a 2x9 set-up.
If you keep to the big ring, it is harder for the trainer to sustain an even resistance & you will find your power trace is more choppy.
I've noticed halfway through a workout that I've been in the 'wrong' ring & upon changing to the inner ring, the subsequent intervals are much 'smoother'.
I did the ZA1 workout yesterday afternoon. It was quite a good one - tough but achievable.
I'm still not sure what the Zwift Academy hopes to achieve? 6 workouts are a solid start, but aren't gonna have a massive impact on your fitness.
Posted : 20/09/2022 4:17 pm
I'm just using ZA as an introduction to the concept of a training programme. I hope to undertake something a bit more meaningful/effective over the winter. My major concern is that strict adherence will rule out "pleasure" rides when weather allows.
Posted : 20/09/2022 4:26 pm
 DrP
Zwift used to be pretty strict and prescriptive for it's training plans...
An update several updates ago made it a bit more leanient, which is good.
I mean, you'll get the MOST if you stick to it religiously, but.... in reality you'll struggle to fir 5+ rides a week in, PLUS real life rides and kids etc!!!
Do what you can - it all helps!
DrP
Posted : 20/09/2022 5:19 pm
I’d recommend Trainer road for a training programme. It’s more flexible than Zwift from what I hear. I’m going to try Zwift for racing but keep trainer road for a training plan.
If you get to a workout and you don’t have enough time it lets you pick a similar alternative with a shorter duration. Or you can just browse the list based on type of workout / duration / difficulty etc. Really good.
New cardio fan position on my turbo table right in my face is excellent - it’s powerful enough you need to keep your mouth shut otherwise it blows your lips about like a dog sticking their head out the window of a moving car 🤣
I think I pushed hard enough I nearly passed out after - the fan kept me going right up to 186bpm on the heart rate. Got a 240ftp which is better than I expected after so much time off my bike. Pretty much had nothing left - that’s the best attempt at a ramp test in terms of extracting every last bit of leg power / lung power I had to give.
Posted : 20/09/2022 8:15 pm
They're both pretty prescriptive, you'd be better off sticking your social rides in a planner, then figuring out what your weaknesses are and planning a few specific sessions around those with some common sense around recovery etc.
e.g. if you do Wednesday night as a chilled evening group ride, and a long ride on Sunday morning, stick in some appropriate interval training on Tuesday (when your fresh from Sunday), and Thursday or Friday once you've used Wednesday as a recovery ride.
Rigid adherence to a generic plan isn't going to be optimal in any sense anyway. So a generic plan that says do 4 x 10min FTP intervals every other day isn't going to be optimal if either you're not fit enough to do that every other day, or fitter than that and would get more benefit from doing 5 (or more) intervals. That's why real life coaches are £££ more than off the shelf training plans, it's the reviewing.
Posted : 20/09/2022 8:30 pm
Yes - although trainer road now has adaptive training. It’s early stage but based on your feedback from each workout it will change what you have scheduled. So if you find one too easy it’ll modify what’s coming up and vice versa. I’ve found it quite decent so far with that.
I always select low volume training (3 times a week) and see how that fits in with what I have planned outside. I suspect I’ll mostly do one mtb ride on a weekend of a reasonable length. Then one Zwift race midweek with 2 trainer road sessions around those
Posted : 20/09/2022 8:33 pm
Mini Me
I can’t inspire you with the internals as it’s not finished but I’ve just erected this Tuin log cabin in my garden for my static bike and as my bike workshop. Next jobs are flooring and electrics. Sometimes I get an audience:
Audience
Posted : 20/09/2022 8:51 pm
Cheers for the replies above about Apple TV, I'll make sure auto update is on.
Which bit says ‘coming soon’ – the app store or zwift itself ?
When I'm in the app store, I click the button that says "update," the screen goes blank, then a very pair pink colour and it says "coming soon!" across the middle of the screen.
I can delete and reinstall the app so it's no big deal really, just a pain in the arse coz I have to re-enter my log in details every time
Posted : 20/09/2022 9:15 pm
joebristol
Yes – although trainer road now has adaptive training. It’s early stage but based on your feedback from each workout it will change what you have scheduled. So if you find one too easy it’ll modify what’s coming up and vice versa. I’ve found it quite decent so far with that.
Ever looked at Xert? It does everything you say there automatically, including adjusting for outside rides (as long as you at least have an HR monitor on). In fact it'll even adjust the workout whilst you're in the middle of it if you're doing better/worse than expected
Posted : 20/09/2022 9:36 pm
Never heard of Xert. Sounds cheap at $9.99 a month. Would have to see if it’ll work just off an iPhone or iPad as I don’t have a laptop / Apple TV yet.
I’ll see if DC Rainmaker has reviewed it as he seems to really test things well.
Posted : 20/09/2022 10:32 pm
Would love to get stuck back into some race action but still can’t get the damn app to load.
Posted : 20/09/2022 10:47 pm
I'm fairly new to TrainerRoad but the adaptive training is doing its job, I'm on low volume which is 3 rides a week, with the harder/longer ride at the weekend.
Within this you have your FTP but you also have workout levels, as you complete workouts you progress within those levels, obviously a higher level means a harder workout. There's a perceived exertion question after most workouts, if you answer relative to to workout (so easy/moderate for a endurance z2 workout) it'll progress your level so the next workout is a bit harder.
It does start you off at level 1 for everything so it'll be a little easy to start with but as Joe said if you've done a ride that should be within your ability and you found it really hard, it won't put your level up so won't make next week's workout as hard or harder. When you get an FTP bump it also reduces your levels a bit, as you'll be going up in difficulty with the increased FTP so it chooses easier workouts to be at the same level.
I had my first missed workout of the plan on Sunday, really wasn't feeling 1.5hrs of over/unders so it automatically adapted the training and moved this workout to this weekend.
Including outside rides within adaptive training is something that's coming on TrainerRoad so that should be good.
They also have the AI FTP, which for me (on a single test) has been 100% accurate. 😜
They’re both pretty prescriptive, you’d be better off sticking your social rides in a planner, then figuring out what your weaknesses are and planning a few specific sessions around those with some common sense around recovery etc.
Unfortunately for me I need workouts in the calendar or else I don't do them, having 3 set rides every week is a good thing for me.
Time will tell though - tbh the main thing it gives me over zwift training is more options, there's not that many training plans on zwift when you look at it. My TR plan has 2 base phases, a build phase focused on short power (for me) and then a speciality phase based on gravity riding (enduro/downhill). And you can put in events so it can build you up to those events and then taper off the week before. It's just a lot more training focused that zwift!
Get out! 😲😎
Jesus that's a zwift cave with a view!! Bastard! 🤣
Posted : 20/09/2022 10:58 pm
Had a look at Xert and not sure about it. I think adding Zwift alongside trainer road for the winter is probably best for me and going to give that a go
Posted : 20/09/2022 10:59 pm
Zwift running with TrainerRoad below it on the same screen is perfect for me, keeps the engagement of zwift with the route completion etc but you get the far better training schedule/features of zwift. TR on its own can be a bit too dull tbh.
Posted : 20/09/2022 11:04 pm
I do a Xert - Zwift combo most of the time. Works well too for that extra little bit of engagement
joebristol
Anything in particular you’re not sure about? From memory the DC Rainmaker review is pretty old, so I might be able to answer some questions. Turns out I’ve been on it since 2019, found it worked far better for me than TR
Posted : 21/09/2022 1:06 pm
I just tried a road bike again.
In some ways I like how they make power, it does in some ways seem easier than the hybrid to increase power and in some ways to cruise too.
But they're really not nice on hands/arms for me, even trying various positions didn't help much.
https://zwiftpower.com/events.php?zid=3110927
I tried 3 times to break, one of the me and 4 others managed 3s on the group, but as with most C races, it ended in a sprint. I'd flogged myself too much trying to break it up.
Posted : 21/09/2022 1:21 pm
 vww
Apologies for hijacking this thread with a beginner question, but there appears to be tons of knowledge on here and this is hopefully a simple question! If I had a smart trainer and didn't want to use Zwift etc (it's a lack of convenience and to some extent cost thing), what options are there for running a workout from my Garmin Edge?
I've looked on Garmin Connect at workouts, but they all seem to be strength/conditioning. Training plans sound right but really, I just want 2 or 3 programs to run when I have the time, rather than trying to commit to a weekly program. Is there anywhere you can get a basic interval session, put it on the Edge, press play and have it control the trainer accordingly?
Posted : 21/09/2022 2:39 pm
vww
Apologies for hijacking this thread with a beginner question, but there appears to be tons of knowledge on here and this is hopefully a simple question! If I had a smart trainer and didn’t want to use Zwift etc (it’s a lack of convenience and to some extent cost thing), what options are there for running a workout from my Garmin Edge?
From a quick look online, it seems to be possible. I've not tried it though.
Garmin Support
Posted : 21/09/2022 3:11 pm
mashr
I do a Xert – Zwift combo most of the time. Works well too for that extra little bit of engagement
@mashr - how do you find Xert? I have been doing workouts regularly with robbo1234biking providing some great workouts to follow for a while now.
But, I quite fancy trying something like Trainerroad or Xert (or have just seen AI Endurance too) over the winter & see if I get stronger gains than I have been getting. The idea of adaptive training seems like a good one & robbo has been getting great results.
But, honestly - I don't really want to pay a great deal for it given that I already pay for a Zwift subscription, so am wondering whether Xert is any good. It's quite a bit cheaper than trainerroad.
I struggled to find much info on it yesterday when looking & it looked quite 'complicated' compared to Trainerroad with lots of metrics & displays on the screen.
I gather that you can run it at the same time as Zwift, so you can do the workout in a Zwift environment & let Xert control the trainer, while Zwift just reads off the power data coming from the trainer, rather than controlling it.
Posted : 21/09/2022 3:17 pm
But they’re really not nice on hands/arms for me, even trying various positions didn’t help much.
Isn't that just a case of swapping the chainset and/or cassette out?
Posted : 21/09/2022 3:29 pm
Isn’t that just a case of swapping the chainset and/or cassette out?
Nah not really. I've had a road biased chainset on the hybrid before, was running a 2x with a 50 as the biggest on the front, but i think it's to do with the actual riding position, or maybe even rotational weight of the road wheel/tyre being lighter than the hybrid... but i think on the roadie you're getting more into the weight towards the front and i think it's not just for aero that roadies are in a forward position.
In the same way an XC race bike is longer and lower at the front, which i'm guessing helps putting the power down.
Posted : 21/09/2022 3:36 pm
@stumpy01 will give you a proper response later on, my work is making me work and its getting right in the way of faffing!
For now though - it's only complex as you want it to be. I just login on the iOS app, see what its suggesting (either based on continuous improvement or having an event date sent), filter to suit based on time available and crack on. It adjusts me FTP accordingly, it looks after how fresh I am (can be tweaked if you're feeling rough/great).
The maximum power available (MPA) is quite interesting. Some folk use it whilst racing but I'm not a fan. However it is interesting to see if confirm just how ****ed you felt when you have a look afterwards
Posted : 21/09/2022 4:11 pm
I think it must be a position thing ref the different bikes.
I sometimes put my race bike on the trainer and it does feel ‘nicer’ than the Triban that lives on there I guess but as for gearing- I don’t even think about it or notice a difference. Just ride in the one that gives you the right amount of watts at the right cadence 🤔🤣 Anything else, you should be able to smooth out with trainer ‘difficulty’.
It’s only in ERG mode where I notice a difference between gearing and on the Kickr SNAP and I like lots of inertia in the big chainring. For many direct drive turbo’s, the advice is little ring but as a simulation for flat real-road riding, I not only like a wheel on trainer but as I say, like the high inertia, short power stroke of the big chainring.
Posted : 21/09/2022 4:50 pm
Cheers mashr. It sounds like it might be worth a go.
Posted : 21/09/2022 10:53 pm
I've tried 2 workouts since i completed my last ramp test and i just can't stick them at all....
I think my FTP went from 255 to 288 and the workouts just seem incredibly hard now.
I'm going to try another tonight to see how i get on.
Posted : 22/09/2022 11:14 am
 DrP
AS i understand, the ramp test can over-estimate the FTP... hence why you may be struggling?
Try something like 270 watts to see how you feel?
DrP
Posted : 22/09/2022 11:30 am
That's a big increase, 13% - unless you're newish to training where you're seeing newbie gains it might be overestimating it.
Also, if you're mid training plan in zwift then the training plan will normally have increased load as part of it, upping your FTP will have have increased the load a second time.
Posted : 22/09/2022 11:34 am
What sort of workouts @beer247? A high IF VO2 max session should always be hard, but if a sweetspot sesh has you gasping there's something up with ftp.
There's something to be said for going slightly conservative on a ramp test imho - like giving it death on your absolute best day can give you an ftp value at the absolute top of the error bar, and training off this will be counter-productive.
Posted : 22/09/2022 11:38 am
Yeah, a sweetspot session was killing me last night - 5mins at 275w then 5mins at 255w x 4
Got through the first set and couldn't hold on through the second.
I'm defo not a newbie, but have only just put the bike back on the trainer.
Maybe i'll look at dropping the FTP manually.
Posted : 22/09/2022 11:54 am
@beer347 For me, ramp tests have always given higher estimates than doing a "negative split" Tempus Fugit TT and looking at my best 20mins.
https://intervals.icu/ will give you an eFTP value off recent power data, by default looking at 5min+ efforts.
I was a bit dubious that Intervals reckoned mine had only dropped to 291 from 306 after my late July Covid that really hit my sustainable power, when I thought it was more like 250-270 through at least all of August. I've definitely started to feel stronger since around the start of September, but I was really surprised to do 324 for 10mins51secs in the rubberbanded first Zwift Academy '22 Baseline ride up Volcano KOM on 12th and then 291 for 16mins34 outdoors on Monday up a 4-mile climb.
Posted : 22/09/2022 12:03 pm
Yeah a sweet spot session shouldn't be kicking your arse. I'm typically under 150bpm until the last 5-10 mins (of 3x 12min @ 85%) of a SS workout, and my max HR is in the high 180's.
Comfortably hard is my description 😁🤣
Posted : 22/09/2022 12:06 pm
Yeah, as above - FTP ramp test for me is always over-optimistic when it comes to doing actual workouts with that FTP applied.
I always knock it back a bit. I should probably stick to the 20min test, but they are horrendous so can't bring myself to do them 🙂
Posted : 22/09/2022 12:10 pm
 DrP
I should probably stick to the 20min test, but they are horrendous so can’t bring myself to do them
Tru dat!
But,.... once you do them, you figure out they are hard but useful!!
Pick a flat route to do it on...
DrP
Posted : 22/09/2022 12:18 pm
I don't know what's worse tbh, trying to churn out nearly 380w for a minute when you've got nothing left, or trying to hold 295w for 20 mins solid.
Neither is "fun". 🤣
Posted : 22/09/2022 12:24 pm
Did anyone mention that Xert works without FTP tests? I should really be on commission 😉
Posted : 22/09/2022 12:26 pm
I don’t know what’s worse tbh, trying to churn out nearly 380w for a minute when you’ve got nothing left, or trying to hold 295w for 20 mins solid.
Neither is “fun”. 🤣
Yeah I know that feeling. My last test earlier in the week I fully drained myself. Massive fan on full power right in my face, had a wobble when I got off the bike and thought I was going to pass out / be sick for about 5 mins after. Maybe 240w might be optimistic as a result but will see on my first sweet spot session tonight.
TrainerRoad has an automatic ftp estimating function that I’ve looked out out of curiosity a few times and it was only a few ftp different to past ramp tests. Maybe I weirdly like the ramp test challenge 🤷‍♂️
Posted : 22/09/2022 12:40 pm
I've dropped down to 275w to see if that makes a difference - i enjoyed (as much as you can) indoor training last winter and it really did make a difference to my summer riding.
Posted : 22/09/2022 1:13 pm
This seems the most active Zwift thread so will post here.
Tuesday 27th 19:30 London Classique chilled ride with optional sprints. All are welcome.
https://www.zwift.com/events/view/3148249
If anyone would like to sweep please let me know. Or lead (then I can sweep!)
Late join is on.
Posted : 22/09/2022 7:05 pm
What does sweeping mean in Zwift terms?
Posted : 22/09/2022 7:06 pm
If people fall of the back of the group someone to lend a wheel to get you back on the group. Would need to be a strong rider
Posted : 22/09/2022 7:07 pm
If I'm back in time I'll happily lead mate. Should be
Posted : 22/09/2022 7:09 pm
If you aren’t in the club and want to join use the link below. You can be in multiple clubs so doesn’t matter if you are in one already.
https://www.zwift.com/clubs/fcbd9c17-1ff8-4477-8104-3408856e0084/home
Posted : 22/09/2022 7:45 pm
 DrP
I'm jumping on the 0930 zwift academy workout #1 today, if anyone fancies it?
(A workout...)..
Did the base ride yesterday... not been told my 'phenotype' yet however!
Hopefully it'll be a bit cooler in the paincave this am!
DrP
Posted : 25/09/2022 9:54 am
Critique my potential Zwift set up.
Monitor
https://www.argos.co.uk/product/9428463?clickSR=slp:term:smart%20tv:1:315:1
Trainer
https://www.tredz.co.uk/.Tacx-Flow-Smart_237207.htm?sku=789349&utm_source=google&utm_medium=cpc&utm_campaign=Turbo%20Trainers&gclid=Cj0KCQjw1vSZBhDuARIsAKZlijSTqDPKC7C1MrxPpSfXebFs6iIGFbBAenB1uSKTRHPat6iO99ZMWcoaAk-KEALw_wcB
Have a bike obviously but is this all I need ? Guessing I’ll still need to connect my iPhone ? Or does using smart tv negate this.
Posted : 05/10/2022 11:18 am
Zwift won't run on the TV, so yes you'll need to run zwift on a device to then have that display on the TV. Presuming your phone will be able to cast to the TV, that should work.
Have you tried running zwift on your phone and casting it to a TV to check it's possible?
Is your bike a QR rear hub?
Posted : 05/10/2022 11:40 am
Yes rear qr wheel. No haven’t really got beyond figuring out what I need. I’ve an iPhone 12 Pro Fwiw ? So if I still need to cast via phone I guess it doesn’t need to be smart tv ? Just able to plug in via usb to display?
Posted : 05/10/2022 12:00 pm
This is mine, first time back on it for ages this lunchtime, mainly driven by the fact that its lashing it down.
2nd Direto is for the kids when they can be bothered
Posted : 05/10/2022 2:43 pm
Did my first race in over a year last night - to say it went poorly would be an understatement.
Cat D - 1 lap of Richmond:
Off the line at roughly 7wkg only that doesn't seem to be the technique anymore so I was way off up the road with everyone else sat at 2.5ish so I looked like a bit of a knob, once I realised this I sat-up to wait, immediately dropped my chain because I've not been using shifting on the few workouts I've done since getting Zwift up and running again and subsequently went from 7wkg and 10 seconds off the front to 0wkg and 30 seconds off the back whilst I sorted that out.
Caught what was the second group on the road but they were steadily losing ground to the front 6 or 7 so I decided once the limited climbing was done I'd try and bridge over aiming to make the catch before the long descent where I could have a breather. Made the catch, closed about 35 seconds on my own, felt pretty pleased with myself tbh.
Then it turns out that it wasn't a one lap race, it was half a lap, 7 laps of a circuit and then the second half of the lap, so that descent I'd been aiming to make the catch for didn't come along for another 30 minutes - I was properly hooped.
Couple of laps of this mini-circuit in and the C's appear so I jump onto them and gradually get towed clear of most of the D's I was with. Until I try to use a power-up with the apple remote, bring the menu screen up because the remote is shit and then dropped the remote. So I had to hop off the bike again, pick up the remote, jump back on, sort the screen and get going. I'm now 30 seconds behind the group I'd just been towed clear of, once again looking like an idiot.
After making the catch again it was all about hanging on for grim death as we went round and round the circuit again and again, praying for the point we could leave and continue the actual course. Rested on the descent as per the original plan and then got dropped like a stone on the final climb getting 4/17 in Cat D, only it was 5/17 really because the actual 4th placed person had stopped a fraction early and not crossed the finish line.
4/10 - would not recommend, will do again.
Posted : 05/10/2022 3:03 pm
Just about to take the plunge myself and give Zwift a go (my last experience of indoor 'training' being one ride on an old style turbo staring at a garage wall and deciding it wasn't for me). Have a Stages SB20 bike due in the next few days, going to try it in my flat initially (as my garage is full of junk and I think if I had to make the extra effort of going there to use it I'd probably end up being too lazy...).
Planning on just using my iPad to start with and then if I (hopefully) really get into it look at either an AppleTV set up or resurrecting my old gaming PC and hooking it up to that. I've also been looking at those VacMaster fans and trying to convince myself it would be worth splashing out on one, I guess the people with two are doing some proper training so hopefully one will be enough for me for a while!
I've been completely sedentary for 5 years so just planning to bimble around Watopia for a bit and then after a few weeks hope there's some really slow group rides I can tag onto...
Posted : 06/10/2022 9:26 am
^^^ I am a few weeks in front of you , having taken the plunge into a trainer and Zwift last month. I am old and slow and doing a few rides a week now, with a pace partner, or workout based. Seems to be good fun. I have no real intention of getting into racing, however it seems an entertaining place to spend an hour a few times a week. Also using iPad, which is good enough for me (on a new Wattbike Atom), along with Companion App on my iPhone. A bit tv would be nice, but not feasible in my garage setup.
I also bought the Vacmaster with remote - I am very glad I did it is ideal
Posted : 06/10/2022 9:38 am
Silly question time, about to start using zwift after a short trial last month, last month I used Zwift on my Apple TV with my Zwift account not linked to any accounts, I then recorded the ride on my Garmin Device for upload to Garmin connect which then passes the ride to Strava.
If I link My Zwift account to my Garmin Account, can I stop recording on my physical Garmin Device? and will Garmin Connect will still pass it to Strava?
Posted : 31/10/2022 10:22 am
Correct.
I'd set it up then do a very short ride to make sure it's all syncing, just to make sure.
FWIW if you are doing any Garmin Connect Challenges then Zwift distance won't count. There is a convoluted way around this though.
Posted : 31/10/2022 10:26 am
Connect Strava and Garmin to Zwift and it'll do everything for you.
If you have a watch/device that can calculate vo2 max then you'll need to sync the device after the ride shows in garmin connect, then wait a min or 2 then drop another sync, this will update your training load and vo2 max in Garmin.
Posted : 31/10/2022 10:47 am
I'm not looking to get on Zwift, but I am needing something to stave off the boredom of turbo sessions - I'm only meant to be doing 1 hour at a time, but I'm struggling with just a half hour.
About to move the turbo to a dedicated space so could be adding some tech to help entertain my brain whilst my body is getting hurt. I'm not wanting an iPad, but what tablet is out there that is a decent size and will allow me to access whatever streaming services I have?
I don't want a big tv screen as although I've got space, it is used for other things as well so turbo with bike and fan are going to be there and anything else I need to use will need to fit amongst other stuff...
Aware this thread is more about getting Zwift all sorted and stuff, but it does look like there are a few different setups people are using. I'm not needing a computer as I don't have a smart trainer so it wont interact with Zwift anyway.
Posted : 31/10/2022 11:17 am
I’m not needing a computer as I don’t have a smart trainer so it wont interact with Zwift anyway.
Do you have some kind of structure to what you're doing though? Just sitting and spinning on a turbo was actually used as a form of torture in the American revolutionary war*
*true fact
Posted : 31/10/2022 12:10 pm
Last year I decided to treast myself to having the same saddle on the turbo bike as my normal road bike - this, it is now apparent, was a mistake. So I've just replaced the saddle for something with a bit more "room". Initial test rides are good, so instead I've started having connection issues between the turbo and the laptop/Zwift - ffffffuuuuuu.......!!!!!
Posted : 31/10/2022 12:12 pm
Heads up if anyone is looking for a smart trainer, wiggle have the Elite Direto for £385 which is cheap for a direct drive trainer.
https://www.wiggle.co.uk/elite-direto-smart-turbo-trainer
Last year I decided to treast myself to having the same saddle on the turbo bike as my normal road bike – this, it is now apparent, was a mistake. So I’ve just replaced the saddle for something with a bit more “room”.
Yeah riding on the trainer for an hour is completely different to riding outside for an hour, I've had to buy extra wide, carbon soled ultra stiff roadie shoes to combat 'hot foot', and a saddle with a cut out for numbness. I'll be looking to build a rocker plate over winter too.
Posted : 31/10/2022 12:16 pm
Yeah, got a training plan (from Garmin - Garmin is seeing how unfit I am and finally offered me a free training plan to get me going - does seem to be working but the 1 hour turbo sessions are an absolute struggle and I think I need something to distract the brain or keep more of my attention)...
Posted : 31/10/2022 12:21 pm
 DrP
@dickbarton
If you're looking to get into using a turbo, and stave off boredom...any reason you're avoiding Zwift or the like?
I mean, they REALLY do help keep you on the turbo for 60-90 minutes...
But ultimately, it seems like you jsut need a TV near your turbo, tbh.
DrP
Posted : 31/10/2022 12:25 pm
If just chasing graphs then I have to have something on in the background too, nothing that requires really concentration. e.g. think 80% of the Marvel movies I've seen have been whilst in the turbo, couldn't tell you a thing about any of them
I’ll be looking to build a rocker plate over winter too.
Keep getting tempted in then shying away. For a while tri_sports_resort (Wiggle) kept selling them on eBay, now kicking myself for not getting one!
How much were they on eBay? They're £150 on wiggle at the moment. Issue is I need one with wheels as I have to move my set up about.
Posted : 31/10/2022 12:30 pm
They were auctions so it varied a bit, sub £100 iirc. I'd forgotten they were £150 on Wiggle at the moment too - really need to just bite that bullet
Posted : 31/10/2022 12:32 pm
I'm not looking to spend a lot...I've a turbo trainer with sensors, a bike to sit on the turbo and a plan to give me something to work through. However, the sitting with no scenery changes is killing my attention and I'm fighting to stay on for more than a half hour - body and legs feel great but head is utterly bored.
So something to watch might prove the tipping point and let me complete the hour sessions. I'm still outdoor riding so the turbo is more for specific sessions, so not looking for anything fancy...unless I can do it on the cheap.
Posted : 31/10/2022 1:46 pm
However, the sitting with no scenery changes is killing my attention and I’m fighting to stay on for more than a half hour – body and legs feel great but head is utterly bored.
What intervals are you doing? If it's 45 mins of steady non changing power then even watching zwift it's boring as hell.
However do some under overs, or VO2 max intervals and you'll be concentrating so much on getting through the intervals you won't have a chance to be bored!
Posted : 31/10/2022 1:56 pm
Honestly try zwift I’m just up and running a week on mine. Absolutely love it so much choice/options of easy solo riding/pace partner/group rides and races. Not to mention all the training plans. I came from turboing years ago staring at a wall !!
This really is a gamechanger for me 🙂
Posted : 31/10/2022 1:57 pm
Dunno if this is any good & not really the answer to your question, but have you seen this?
https://mywhoosh.com/
It's apparently completely free and relies on ads for revenue.
But, the ads are in-game rather than being obtrusive banners or pop-ups.
I saw an article a few days ago reviewing it (but can't remember where now).
If you just want a tablet that can stream films etc. I would have thought any mid-range tablet would be more than up to the task.
Posted : 31/10/2022 7:03 pm
Page 3 / 4
