Alloy post in carbo...
[Closed] Alloy post in carbon frame .... Do I need carbon assembly paste?
As above.
Not sure copper slip is going to be the answer this time around! ๐Ÿ˜†
Posted : 07/06/2012 12:16 pm
yup.
Use the proper stuff. Worth it.
Posted : 07/06/2012 12:17 pm
Cheers squire.
When you say [i]proper stuff[/i] do you mean carbon paste over copper slip or is there a specific brand I should look for?
Posted : 07/06/2012 12:19 pm
the proper carbon stuff. I use the finishline stuff but I don't have any preference, was just what I could get at the time. Really does help reduce the clamping force needed too. Just apply a really thin smear - not too much. A thin layer will be less likely to scratch the post if you move it a lot.
Not copper slip as the base used in copper slip can swell plastics. As I found with rear drum cylinder seals after being told to use copper slip by a dealer I worked in as a kid. Now I use stuff I know is safe on brake seals and save the copper slip for metal only parts.
Posted : 07/06/2012 12:24 pm
Thank you again.
Will see if the LBS stocks it.
Have also heard that toothpaste works ....... ๐Ÿ˜
Posted : 07/06/2012 12:29 pm
๐Ÿ˜† I can see the thinking - especially whitening with crystals in and should work as an emergency measure. But being water based I suspect it will just wash down the seat tube and you will have to keep applying it and get a nice minty residue down inside your frame!
I suspect you can make your own with a bit of silicone grease and some very fine silica (sand) but for the sake of trying it and getting a too sharp sand and scratching the crap out of your post it's probably not worth it.
Posted : 07/06/2012 12:37 pm
Get a can of cheap hair spray and spray the post. (I am being serious)
Posted : 07/06/2012 12:45 pm
Normal petroleum based grease can cause carbon to swell, so its worth using the right stuff.
Posted : 07/06/2012 12:47 pm
Having seized a carbon post in an ally frame a few years ago (as in frame no longer useable) I have since bought a little tub.
DO IT!
You know it makes sense.
Posted : 07/06/2012 1:02 pm
also if you use anti slip paste it means you dont tighten it so hard to stop it slipping and cause damage to the post
Posted : 07/06/2012 3:14 pm
