alloy is dead (appa...
[Closed] alloy is dead (apparently) - carbon is the only way forward!
 D0NK
then there's an ease of repair question
just being pedantic but isn't it "cheapness of replacement"? didn't think you could do much to repair ali stuff.
broadly agree tho.
Posted : 26/04/2011 12:11 pm
If you're a Ninja, this may interest you 🙂
Anyway, once you've heard enough of the preamble - FF to 12:50
Posted : 26/04/2011 12:15 pm
aluminium has it's uses - in places were you need something chunky but need to keep the weight down.
As for impact - nice thick chunks of metal - alu alloy or steel etc - no problem. You make hammer heads out of big heavy chunks or metal for a reason.
Impacts onto thin walled metal tubing - no thanks. If you are lucky and get a bend the part is now plastically deformed and the load path is different and the material is no longer consistent thickness. If you are unlucky you get a little hairline crack which will grow very quickly in a dynamic application.
Composite impact - yup it can get nasty but a delamination does not mean failure is imminent. Fibre failure does but fibre failure is significant. Most frames should be designed for rocks being thrown up. a 50g rock at 30mph is about 5J. If the carbon is not designed to take that itself then it really doesn't need much protection to protect it (have a paper due out on this very subject)
For anyone worried about composites surviving a harsh life then go buy a fibreglass handled sledge hammer or mattock and give it some stick: http://www.toolstation.com/shop/Hand+Tools/Axes+Picks+Sledgehammers/d10/sd3179
You would bend a metal handled one very quickly - that is if your hands and arms can take the vibrations.
Posted : 26/04/2011 1:45 pm
uplink - Member
Arghhhh so much abuse of engineering terms but nice demonstrations. Would like to see bamboo compared to them too and mention of weight (for specific strength)
Posted : 26/04/2011 2:05 pm
Page 2 / 2
