alfine 8 speed, spr...
[Closed] alfine 8 speed, sprocket is loose
I am trying to install a Shimano Alfine gearbox, but the sprocket is loose. When I install everything and put the wheel on my bike, the sprocket wiggles right and left. I bought all the parts myself and built the wheel. Here is what I bought:
Hub gearbox, except non-Di2 version
https://www.bikeparts.co.uk/collections/hubs/products/shimano-sg-s7051-alfine-di2-internal-hub-gear-8-speed-32h-silver
Sprocket: https://www.ebay.co.uk/itm/254824352725
Hub components: https://winstanleysbikes.co.uk/shimano-alfine-sm-s500-hub-components
Details of assembly & instruction manual to follow. Building a Rohloff is more idiotproof than a Rohloff.
Edit: I'm following this Dealer's Manual from Shimano.com
https://si.shimano.com/api/publish/storage/pdf/en/dm/SG0004/DM-SG0004-06-ENG.pdf
Posted : 06/02/2021 3:12 pm
did you put the locking circlip on properly? the sprocket does float a little but not very much
Posted : 06/02/2021 3:13 pm
@tjagain I don't know what about that prompted me to try the clip again, but BOY that was fiddly. I think I have it on. My technique was to sort of prize it on bit by bit, plus a lot of brute force.
Posted : 06/02/2021 4:02 pm
It can sit just ourboard of the proper grouve. It should go in with a positive click - there should be cutouts to help with getting it on.
Posted : 06/02/2021 5:43 pm
Now I can't get the "cassette joint" on ๐Ÿ™ I follow the instructions carefully, but the "cassette joint fixing ring" isn't low close enough to click on.
A few things:
- The "cassette joint pulley" doesn't perfectly match the one on p13 of the instructions. In the instructions, the hook shaped opening points to the rear. Mine points down.
- The "cassette joint pulley" sort of shakes around. It's as if something is taking up space so it can't get close enough to the sprocket.
What exactly am I doing wrong? ๐Ÿ™
Posted : 14/02/2021 4:57 pm
I think I've spotted the problem: the cassette joint & the gearbox are "toothed" so they match up. Problem is the cassette joint has 8 "sockets", but the gearbox has 10 "teeth". It makes sense that the cassette joint will sit higher up than it is meant to. I'll try and upload pictures.
Where can I find the right cassette joint?
Posted : 14/02/2021 5:34 pm
Posted : 14/02/2021 5:57 pm
It seems like you need the correct cassette joint for the hub. I didn't know they differed but in the OP you state hub is a different number from the cassette joint
~Try SJS?
Posted : 14/02/2021 6:03 pm
@tjagain thank you. I have ordered this one
https://www.sjscycles.co.uk/hub-spares/shimano-alfine-sgs70008-cjs7000-cassette-joint-unit-y7zr98010/
I don't understand why they need to make several different types.
Posted : 14/02/2021 8:03 pm
'cos they are shimano!
Posted : 14/02/2021 8:08 pm
