alfine 8 service /o...
[Closed] alfine 8 service /oil bath question alternative oil to shimano?
Hi folks another alfine question sorry
what alternative oil have you been using for giving the alfine internals an oil bath?
i have just given my io id 2009 a bit of tlc
new chain ring,chain and sprocket.
i had a go at the hub and managed to split the alfine and gave it a dip in some 15wt suspension fluid to give it a flush out.
so before i rebuid what alternative oil should i use ?
transmission fluid? if so what type/weight?
thanks DTD
Posted : 13/12/2011 6:05 pm
People have used ATF I believe - I chickened out and paid to have mine dipped in the magic shimano oil in the end
Posted : 13/12/2011 7:33 pm
And the advice for the 11? Katie's needs doing. Can you flush it with Rohloff cleaner then oil?
Posted : 13/12/2011 7:44 pm
will this d http://www.autosessive.com/9/section.aspx/260/Comma_AQF_Auto_Trans_Fluido the job
[url= http://www.autosessive.com/9/section.aspx/260/Comma_AQF_Auto_Trans_Fluid ]cheap auto trannsmittion oil[/url]
Posted : 14/12/2011 9:57 pm
The only info I have is
http://hubstripping.wordpress.com/alfine-shimano/
http://singletrackworld.com/forum/topic/alfine-8-broken
http://lockies.blogspot.com/2009/09/shimano-alfine-hub-gear-rebuild.html
and a few more threads on here. I would go for a synthetic atf perhaps if such things exists. have a search for epicylos threads - I think he has some views on it
Posted : 14/12/2011 10:16 pm
