I've got an Alfine 11 hub and shifter on pre-order from Wiggle, but they don't have the fitting kit listed.
So, is there anywhere else that I can pre-order the fitting kit from - and are the sprockets going to be the same between the 8 and 11 speed hubs so I can go ahead and get one/pre-order this as appropriate?
Thanks.
Posted : 13/09/2010 11:05 am
Sprockets are the same for 8 and 11 speed, codes are CSS50018 or CSS50020 depending on the size. Fitting kit is an SMS700 and any decent bike shop can backorder one for you.
Posted : 13/09/2010 11:09 am
Just checked on Wiggle, this fitting kit should be 11 speed as it contains CJ-S700 which is the 11 speed cassette joint unit.
http://www.wiggle.co.uk/p/cycle/7/Shimano_Alfine_Cassette_Joint_and_Fitting_Kit/5360051008/#more
Posted : 13/09/2010 11:16 am
Genius - thanks gents.
Posted : 13/09/2010 11:27 am
