Anyone got any experience of both? How do they compare on a single pivot Orange (particularly Patriot or Alpine, but maybe Five too)? Only really interested in DH performance and reliability. What about the effect of heat build-up on Alpine descents? Considering a second shock for my bike, for when the CCDB is heavy overkill. Ta.
Ok, what about just the RP23 then?
Funnily enough, yes, I had both on my Nomad.
It came with the current 2012 RP23 Kashima, blah blah etc. I had a previous version before & couldn't really tell the difference the gold coating made. Felt fine, seemed to work well on the bike, like most air shocks on the VPP2 platform it got a bit overwhelmed on repeated mid sized hits, otherwise just did it's job.
I sold it as I wanted a Vivid Air for the bike, but neglected to actually order before I sold the other shock (doh). I bought the Monarch as a stop gap until the Vivid arrived as it was only the basic one (3.1?) and cost me £100.
If you covered them up, I probably could tell the difference between the two. The bike still rode just as well with it. It may have felt a little more active on the initial stroke, but that could be due to running less pressure in it to get the required sag.
Hob Nob - cheers for that. And the obvious follow-up question...how does the Vivid compare to the other two, assuming you now have it?
Chalk & cheese to be fair.
I looked at the DBAir, but read/heard a lot of conflicting info about it not working well on the Nomad platform, and to stick with the coil, but I didn't want the weight that brings, this was the only other real choice...
Its been on there a while now, and i've used the bike for most things bar boring pedalfest XC which I don't do anyway. I don't know if its the shock, the tune, the way the suspension works or a combination of all, but it's really very good indeed. As cliche as it sounds, it really does feel like a coil shock on it. It seems on the Nomad to work best around 25% sag on trail riding, but i've raced DH on it too while my DH bike was in bits, just ran a bit more sag & it was spot on.
Very impressive, I have to say 🙂
Interesting that, Hob Nob, thanks. Will have to have a think. Vivid sounds ace, but it's a pile more dosh. Possibly it wouldn't give the same level of improvement on a different frame, too. Sounds like your Nomad's really making the most of it. Cheers.
