Advice - Dura Ace/U...
[Closed] Advice - Dura Ace/Ultegra XTR MTB setup integration?
I'm thinking of running a Dura Ace 10spd rear mech, Ultegra front with XTR shifters.
Has anyone done the same or similar?
Is it a daft idea and more importantly will it work?
The only stumbling block i can think of is the cassette.
Years ago i ran a Ultegra rear with no dramas... so this should be ok right?
Cheers all in advance
Posted : 30/04/2015 11:56 am
Road 10 speed and MTB 10 speed use different cable pulls so it won't work.
What are you trying to build? A flat bar road bike (or hybrid as someone will no doubt point out)?
Posted : 30/04/2015 12:12 pm
go 9 speed for ease of integration.
Posted : 30/04/2015 12:40 pm
Building an XC flyer and want something a bit different. I've the parts in the man cave.
So would 10spd not work?
The 9spd setup I've used before worked flawlessly.
Posted : 01/05/2015 10:24 am
Bodging cheap stuff fair enough...but XTR/Dura Ace?
Posted : 01/05/2015 10:29 am
I have a mtb with an OLD xtr mech (was possibly even a 8sp when it was sold) using ultegra flat bar shifters and it does 10sp pretty much perfectly
Try it, if you've already got the bits
Posted : 01/05/2015 10:43 am
Your mix works because 10s road and all 5-9 speed mechs are compatible.
If you want to waste your time.
Posted : 01/05/2015 10:47 am
Posted : 01/05/2015 10:58 am
๐Ÿ˜ณ seems I misread the OP - 10sp mtb shifter is yer problem there, compared to me. Sorry, saw ultegra front and thought you had a shifter like mine
as ^they said - don't try it, it won't work
Posted : 01/05/2015 11:19 am
