"adjustable ve...
[Closed] "adjustable velocity sensitive shimmed rebound control", explanation required.
7 Users
This is from the fox website chatting about the DHX air.
I'm a little confused by it, does anyone have a correct answer?
Damping force = c * v, where c is the damping coefficient and v is velocity, so in that sense, all damping is dictated by velocity.
Is the fox blurb just reiterating this, or are there goings on in their rebound circuit that mechanically adjusts for high and low speeds?
Posted : 14/07/2011 2:26 pm
are they talking about the fact that the shims bend and adjust the damping depending on how much pressure there is?
Posted : 14/07/2011 2:46 pm
I would take it as being a shim stack - the faster the oil moves the more of the port is uncovered / wider the gap for the oil to flow
Posted : 14/07/2011 2:48 pm
 LoCo
😆 Jargontastic I'm going to use that as often as possible from now on 😕 , yes it's a shim stack or two with an adjustable bypass port.
The RP23 would be a better option, probably 😉
Posted : 14/07/2011 2:50 pm
Its marketing flim-flam to make stuff that you already know about sound really good, funky and new.
Posted : 14/07/2011 2:53 pm
Cant you have "adjustable location sensitive shimmed rebound control"?
Or is that only for compression?
Posted : 14/07/2011 2:59 pm
I thought the DHX was a needle valve with a bypass?
Posted : 14/07/2011 3:03 pm
A needle valve is just a way of producing an adjustable aperture orifice damper isn't is?
I'd have thought the DHX would have had something a little more sophisticated.
Posted : 14/07/2011 6:20 pm
