Adding gears to Hop...
[Closed] Adding gears to Hope SS hub
Thinking of adding a small cassette to Hope SS hub on my 29er(I know - but want to try it, so don't try and dissuade me!). Read up a bit on mtbr, but getting confused on suitable cassettes etc. I know the main part of an XT cassette will fit (17-34) but I want higher gearing - more 11 or 12 to mid/high 20's. Apparently you can use road or mtb cassettes. I've got a Middleburn uno crank 32t and short/medium xt rear mech if that makes any difference.
Any advice appreciated!
Posted : 03/10/2009 3:09 pm
Tiagra 9 speed cassettes can be split open (there are 3 little rivets that need the end grinding off with a dremel). Then you can use whatever cogs you want, although the shift won't be perfect if you add or remove cogs in the middle (shifting ramps and all). They come in a pretty good range, 11-27 is the biggest I think. Not sure if Deore cassettes do the same, but they might.
Posted : 03/10/2009 3:19 pm
Thanks JN. Anyone actually given it a go on a Hope hub?
Posted : 03/10/2009 3:33 pm
 Andy
The other consideration is that if its an alloy freewheel then the narrow individual 9 sp cogs of a cassette will score the carrier. You could try the Groove armadas from On one as these are designed to be built up into a cassette if needs.
Posted : 03/10/2009 4:05 pm
But expensive and heavy??
Posted : 03/10/2009 4:07 pm
Not a problem, as it's a steel freehub.
It's a SS/trials hub, so might be worth asking someone who has a bit more trials expertise ala Tarty bikes or something?
Posted : 03/10/2009 4:52 pm
Weird, just did this this afternoon. Now I'm pregnant I'm not hardcore enough for my ss, so have popped 6 gears on.
I just split apart a Sram 970 cassette (hubby used an LX cassette when he did it a while) and took out every third sprocket so leaving the 2 hardest gears. Just tried it around the block and it seems great, got a couple of faster gears, a couple of medium pootling gears and two winching up hills gears. Ideal.
Hubby just said to remind you that you'll need to pop a 1mm spacer on the spoke end of the hub. Other than that it's very straightforward.
Posted : 03/10/2009 5:17 pm
Btw, even though its a steel freehub bidy, it might score the cassette a bit. Worth it though imo.
Posted : 03/10/2009 5:18 pm
It's just a short freehub body, what is there not to work? As long as you can get the cogs to build up to the correct overall width your laughing.
Posted : 03/10/2009 5:19 pm
Brill. I'll give it a go then ๐Ÿ˜€
Posted : 03/10/2009 5:29 pm
..oh and congratulations btw!
Posted : 03/10/2009 5:30 pm
Thanks! And yeah, re the hub, go for it - it looks pretty sweet too! (Give us a shout if you have any probs, but I'm sure you'll be fine). Cheers.
Posted : 03/10/2009 5:39 pm
