Saw this on tinterweb and wondered if anybody has any experience of the using one?
[url= http://www.woodmancomponents.com/catalog/categorie.php?cat=dis&lang=en&art=dis1 ]Woodman diso[/url]
I used the A2Z one for a while and it worked well, a bit neater than the ones that go all the way up to the v-brake bosses. Only fits certain frames though - fit my Zaskar no problem but not on a '99 s-works.
I have used a Hope one which was very similar. Used an XC rear hub with a modified axle and end plate. Worked well but was a bit of a faff to remove the wheel. Cheaper than a new frame though.
I've used the Hope one on a couple of different bikes in the past. One alloy, one steel and had no issue with either.
i've used the specialized one a couple of times. By far the best design. Once fitted the wheel comes out with no extra faff.
