Adaptor for fitting...
[Closed] Adaptor for fitting forks with straight steerer in a headset for tapered forks?
Hi has anyone come across an adaptor you can fit on a straight steerer so it'll fit in a headset for tapered forks?
I'd like to be able to fit some old shorter coil forks I have with a straight steerer in my hardtail at times instead of the Pikes I've got in it for messing about at the BMX track/pump tracks with my kids.
Long shot I know but thought someone might have produced this!
Posted : 14/11/2018 2:08 pm
Hope do one. I have one sitting spare in a box somewhere!
More usefully, you are able to add an angle adjustment headset. I also have one of those sitting in a box somewhere....
Posted : 14/11/2018 2:18 pm
Cheers Jon.  Is that just for using with Hope Headsets or does it fit to the fork steerer increasing it's diameter to that of a tapered steerer?
I've just fitted Superstar's Slackerizer headset and once I'd build up the bike (old 26" Switchback) I realised I could run a shorter fork for messing about due to the higher bottom bracket than modern frames.
Posted : 14/11/2018 2:26 pm
I’ve used one of the hope adapters. They work great with any headset.
Google: hope-tapered-1-5-reducer-crown
at CRC
Posted : 14/11/2018 2:33 pm
Hope part number HS136
Posted : 14/11/2018 2:36 pm
Reducer crowns are generally what you need but may be specific to the headset. Depends on the lower bearing and seals if any.
Posted : 14/11/2018 9:28 pm
Superstar do a reducer crown race:
https://www.superstarcomponents.com/en/crown-race.htm
Posted : 14/11/2018 9:47 pm
Hope HS136, it's a steerer expander rather than a crown race reducer. Will work happily with any headset. Best go for a headset with a split crown race though to reduce the faffage when changing forks.
Posted : 14/11/2018 10:09 pm
 nuke
I use hope hs136 on two bikes to do what you ask OP, both with none hope headsets...work great but, just to make it easier to insert/remove, i hacksawed a slit through the side of them to make them split adapters
Posted : 14/11/2018 10:16 pm
Thanks everyone 🙂
Posted : 15/11/2018 10:47 am
