A problem with chai...
[Closed] A problem with chains
I have never had a problem before with 9 speed chains and I found that even if the chain breaks I could fix it with a magi-link and it would continue fine for months.
I switched to 10sp last year and built up a new bike in feb. since then the chain has broken five times. I repaired with inserted links. What's going on? Is a chain repaired with a spare link weaker than repaired with a magi-link? I have been running a SRAM chain on a xtr cassette & rear mech and XO chainset so could mixing brands be causing the problem?
Other rants: does anyone else have a problem with 10sp magi links? They're impossible to connect / disconnect!! Any tricks of the trade are welcome. And finally does 10sp make chain-suck worse or is it the XO chainset (always used XT before).
Thanks. I feel better now.
Dickie
Posted : 10/04/2012 9:44 am
Is yours a Shimano chain?
Not sure about magi links but SRAM ones are not separable. KMC make re-usable joining links for 10 speed.
Posted : 10/04/2012 9:47 am
SRAM. The SRAM 9sp were separable but 10sp seem impossible. I will look at KMC thanks.
Any comments about chains repaired with spare links? I am guessing the chain must be weaker where it is repaired.
Posted : 10/04/2012 9:59 am
It'll be made slightly weaker by driving the pins out and back in again, but nothing to worry about for me. I've broken a SRAM quick-link in the past so they're not indestructable.
Posted : 10/04/2012 10:02 am
