A new dawn (DIY bra...
[Closed] A new dawn (DIY brake mount and CARBON CATACLYSM content)
You may recall my DIY fork-disc-brake mount. Which broke 😮
Well I'm having another go and here's a sneak peak of the start of the hand-crafted manufacturing process. Note the use of balsa wood and sellotape (the branded stuff, not any cheap copy).
Updates to follow over the next few days...
[url= http://farm9.staticflickr.com/8500/8403539560_12f92e903a.jp g" target="_blank">http://farm9.staticflickr.com/8500/8403539560_12f92e903a.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/7693620@N05/8403539560/ ]IMG_0024[1][/url] by [url= http://www.flickr.com/people/7693620@N05/ ]alan cole[/url], on Flickr
Posted : 21/01/2013 10:09 pm
I'm with you all the way.
Posted : 21/01/2013 10:15 pm
Now could it have possibly broken?
Posted : 21/01/2013 10:17 pm
To the hospital?
Here we go 🙂 :
Will the caliper be front mounted on the fork? If so, why?
Posted : 21/01/2013 10:19 pm
Nice to see a quality finished job.
You should be pleased with that.
Tim
Front mounted? Wouldn't the calliper try to pull itself off the fork leg when you use the brake rather than push itself on?
Posted : 21/01/2013 10:22 pm
 P20
You're doomed, the rotor is going in the wrong direction. Apart from that it's fine 😆 😉
Good job he works in a boik shop 😯
Posted : 21/01/2013 10:24 pm
Im not sure if the sellotape will work well and the bit of balsa wood seems unfinished.
But then again, that shouldnt put you off.
Well done for having another go 🙂
Posted : 21/01/2013 10:25 pm
You're mental. In a good way 🙂
Posted : 21/01/2013 10:26 pm
front mounted, yes - it seems to me the pull will tension the carbon wrap (to follow) which is how carbon works - rather than try to compress it. Also stops the hhub pulling out of a vertical fork end (important as I use an allen key security skewer).
Posted : 21/01/2013 10:28 pm
Might be OK in Lincolnshire....
Posted : 21/01/2013 10:32 pm
String actuated brakes. It's the future.
Posted : 21/01/2013 10:38 pm
Well it's held on OK, now to get the structural stuff done in carbon.
[url= http://farm9.staticflickr.com/8353/8411509444_31ed18fb27.jp g" target="_blank">http://farm9.staticflickr.com/8353/8411509444_31ed18fb27.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/7693620@N05/8411509444/ ]IMG_0038[1][/url] by [url= http://www.flickr.com/people/7693620@N05/ ]alan cole[/url], on Flickr
Posted : 24/01/2013 3:38 pm
 DrP
What - that's not the finished article...??
DrP
Posted : 24/01/2013 4:36 pm
That's the carbon wrap on..
[url= http://farm6.staticflickr.com/5465/8411022493_4f832b8e35.jp g" target="_blank">http://farm6.staticflickr.com/5465/8411022493_4f832b8e35.jp g"/> [/img][/url] [url= http://www.flickr.com/photos/7693620@N05/8411022493/ ]IMG_0044[1][/url] by [url= http://www.flickr.com/people/7693620@N05/ ]alan cole[/url], on Flickr
Posted : 24/01/2013 7:15 pm
couple of cable ties round that and you're good to go... 🙂
Posted : 24/01/2013 7:22 pm
Into the autoclave then?
you are not fooling me that is just duck tape
Posted : 24/01/2013 7:25 pm
 joat
I think I have some carbon wrap then, it's in with my electrical bits and bobs 😕
Posted : 24/01/2013 7:27 pm
whats that suspicious dribbly whitish liquid?
Posted : 24/01/2013 7:30 pm
The carbon goes on with epoxy resin (the white stuff)
You then put electrical tape on it to squeeze the epoxy out and keep it all in place. what you see os said tape.
Unveiling in a day or 2. Then probably touching up a bit then finishing, fitting & instant death.
Posted : 24/01/2013 8:24 pm
I salute your total refusal to admit defeat, sir, it is admirable. Insane, but admirable. 🙂
Posted : 24/01/2013 8:42 pm
Monkeyjizz
Posted : 24/01/2013 8:43 pm
why on the front? In the normal place would have been better. Tension better than compression. If it goes bad then give me a shout and I'll send you some cured carbon plate to make an IS tab and some UD pre-preg to secure it with.
Posted : 24/01/2013 10:35 pm
andyl - on the front is under tension.
Posted : 24/01/2013 10:43 pm
oops! 😳
been a long day. In that case carry on....The disc was making me think it was spinning the other way.
I think I remember this from the spoon episode now.
Posted : 24/01/2013 10:44 pm
Please tell me you will write your Will before the test ride!
Posted : 24/01/2013 10:49 pm
boblo
Remember to take your oven chips out first, otherwise they taste funny.......
Posted : 24/01/2013 11:27 pm
I hope you'll be mating this to a rotor made out of an old biscuit tin lid and a caliper fashioned from bamboo salad servers. Otherwise I, for one, will feel cheated.
Posted : 25/01/2013 12:07 am
Not looking too bad
[url= http://farm9.staticflickr.com/8508/8413722426_b58d241f47.jp g" target="_blank">http://farm9.staticflickr.com/8508/8413722426_b58d241f47.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/7693620@N05/8413722426/ ]Untitled[/url] by [url= http://www.flickr.com/people/7693620@N05/ ]alan cole[/url], on Flickr
Posted : 25/01/2013 9:17 am
Serious question: Under braking the top is under tension the bottom under compression. What stops the balsa spacer being crushed at the bottom? Shouldn't you have used a non crushable spacer?
Posted : 25/01/2013 9:22 am
Serious answer: the bottom isn't in compression! I checked!
Posted : 25/01/2013 9:35 am
Another question (sorry).
Is there a reason for placing it on that fork leg when it's normally on the other one?
Looks good by the way.
I will follow this thread with interest....
Posted : 25/01/2013 9:44 am
is it really worth the effort when these are less than £70 ?
http://www.wiggle.co.uk/kinesis-crosslight-3-alloy-cyclocross-bike-forks/
Posted : 25/01/2013 9:52 am
Al - for a better finish, you should wrap the tape with the sticky side out (but well done for remembering to puncture the tape to let the air/excess resin out!)
Posted : 25/01/2013 10:01 am
cynic-al - Member
Puzzled. How can it not be? The top will be pulled ( I.e. in tension) when the brake is applied. This must mean the bottom is in compression as the load is not totally perpendicular to the caliper adaptor. Surely? My bet is the carbon wrap will stop this at first then fail progressively as the brake is used and the balsa will be crushed.
Posted : 25/01/2013 10:05 am
I'd have thought the bottom will be pulled too, can't see anything in compression.
Posted : 25/01/2013 10:10 am
[i]is it really worth the effort when these are less than £70 ?[/i]
why spend money on those when the he has a cutlery drawer close to hand.
Posted : 25/01/2013 10:12 am
*ALERT ALERT*
XX CHROMOSOMES DETECTED
*ALERT ALERT*
Posted : 25/01/2013 10:15 am
Slightly puzzled. If those forks were designed for rim brakes, will the fork leg be able to cope with the braking forces applied at the bottom? So is a snapped fork leg just a matter of time?
[i]So is a snapped fork leg just a matter of time? [/i]
he kept his teeth when the last bodge job/carefully engineered solution failed 🙂
Posted : 25/01/2013 10:17 am
Al, out of interest, would the squeezing of the CF / Resin worked better using a vacuum pump and a bag around it?
Posted : 25/01/2013 10:25 am
Yes, but he only had a roll of insulating tape. 🙂
Posted : 25/01/2013 10:30 am
Greek track teams bikes for the Athens games were made using the 'reverse insulation tape' method of consolidation and cured in the back of a car on a sunny Greek day. At the time, they were considered to be more than adequate for the job at hand 😉
Posted : 25/01/2013 10:35 am
Was that in the first Olympics 😉 Point of order... Track bikes don't have brakes.....
Posted : 25/01/2013 10:38 am
[i] cured in the back of a car[/i]
maybe they misunderstood what an 'autoclave' was?
Posted : 25/01/2013 10:39 am
 cb
Airbag on the handlebars...just in case like
Posted : 25/01/2013 10:48 am
Nope!
Irrelevant, to the point that the consolidation method Al is using is perfectly fine, provided the engineering of the joint itself takes into account the effect that the method has on the resulting material strength. Other factors are, of course, at play here... 😉
Posted : 25/01/2013 10:49 am
When he is ready for his first test (crash) can someone please follow him and film it for our amusment - it would be a nice addition to the midweek movies.
A far cry from those massive DH vids and giant jump vids we are tired of watching.
Posted : 25/01/2013 10:57 am
bristolbiker - Member
<snip> provided the engineering of the joint itself takes into account the effect that the method has on the resulting material strength.
Uh oh..... 🙂
Posted : 25/01/2013 11:08 am
Just take a hammer to your teeth/face. It will have the same effect.
Posted : 25/01/2013 11:22 am
I will, as ever, provide a video of the test ride, hopefully tomorrow.
"Show us the spoon"
"Show us the spoon"
"Show us the spoon"
"Show us the spoon"
"Show us the spoon"
"Show us the spoon"
But seriously... well done 8)
Posted : 25/01/2013 11:28 am
Oh and I did put the insulating tape on inside out!
Posted : 25/01/2013 11:40 am
Hmmmm, what will be the failure characteristics ?
Possible theory: If the joint fails in one go with the front lever applied then the caliper will rotate with the rotor and I guess detach from the brake hose if the hose is short or fixed to the fork leg. Otherwise the caliper could remain on the rotor until it collides with the rear of the fork leg...
Posted : 25/01/2013 11:50 am
Like Oak?
Posted : 25/01/2013 11:56 am
Spooky
I've been considering lashing up a rear mount for my SS you previous adventures with composites had me considering something similar to what you've got there, attaching a PM adaptor to the stay and wrapping it...
My other thought was to try and create a bridge between the seat and Chain stays which integrated a pair of 51mm IS mounting hole and applied load to both...
Ignore the doubters Al, perseverance is a sign of greatness
I feel some garage time coming on...
Posted : 25/01/2013 12:02 pm
[i]Like Oak? [/i]
or a couple of fish knives?
Posted : 25/01/2013 12:05 pm
That sir, is marvelous.
Posted : 25/01/2013 12:11 pm
But if you put the mount on the back of the fork (on the left leg) the carbon would be under almost no load at all - all the load would be taken by the spacer under compression. Now granted balsa may not be up to that (though weight for weight it is an excellent material), but it would be quite simple to use something else which would take the load (possibly just a carbon wrapped block of balsa, though a stronger bit of wood would probably be simpler).
Which brings us on to the other point - carbon works just fine in compression, provided (just like any other structural material) it is properly supported to prevent it buckling. How else do you think those carbon forks of yours support the load? The strength requirement to prevent the buckling is far lower than the strength requirement to support the load, and can quite adequately be provided by the epoxy resin bonding the carbon to whatever it is attached to - hence how sandwich constructions provide good bending strength (where one side is in tension, one side in compression). As mentioned above, a carbon wrapped block would provide very good compression strength. The only reason the outer carbon wrap wouldn't do a good job of providing this compressive strength is that you'd be relying on the epoxy bond in tension and shear - the alu mount would likely separate from the carbon.
Posted : 25/01/2013 12:19 pm
 D0NK
go away and think about what you've just said.
then jamming between spokes and fork locking the front wheel, test ride will no doubt be a slow speed affair, but presuming that's successful (hell of a presumption) how fast are you going to go in future? how much faith do you have in your bodging skills Al?
Posted : 25/01/2013 12:20 pm
Insanity: doing the same thing over and over again and expecting different results.
Posted : 25/01/2013 12:21 pm
just 😆
Posted : 25/01/2013 12:27 pm
i look forward to the results of this thread. I also applaud Al for looking beyond the "black magic" of bike design and having a go at it himself
Posted : 25/01/2013 12:28 pm
[i]i look forward to the results of this thread.[/i]
I think everyone is. Especially with the promise of video evidence 🙂
Posted : 25/01/2013 12:30 pm
Yup, that's why I did it this way.
cookeaa - Member
Spooky
I did similar on my fatbike, shaped the mount to brace against the stays and then wrapped it in place.
Posted : 25/01/2013 12:46 pm
You didn't consider the idea of the spacer being structural - which would be a far better engineering solution?
Posted : 25/01/2013 12:51 pm
Yep Al that sounds just like what I've got in mind...
The only other thing I was considering was making a Jig plate to line the brace up accurately relative to the Dropout and using Devcon or something similar to position it prior to wrapping, devcon when set can deal with a bit more loading and is easy enough to shape, sculpt and can be dremeled/machined after it has set...
Posted : 25/01/2013 1:06 pm
What is the torque applied to a brake mount? I presume it's a result of the clamping force (which has to be pretty high on a disc) x friction coefficient x the diameter of the disc.
I suspect in a disc brake these forces add up to quite a lot. I'm not sure I'd trust such a solution myself but Chapeau for trying...
Posted : 25/01/2013 1:37 pm
cookeaa I use a cable caliper and hub/wheel with a disc attached to line it up -works fine.
aracer - Member
Why "far better"?
Posted : 25/01/2013 1:45 pm
Not the best I have seen, but full marks for the innovative approach. However, if you really intend to use this things there are somethings you should be aware of (maybe you already are).
Carbon composites, work best in tension, rather than compression and their strength or rather performance will be affected by a number of factors. The braking force is probably going to induce mostly tensile in your bracket, although there could be the possibility of a moment there that could put the lower part of the bracket into compression. If I were you I would be sure to have a fed wraps of continuous fibres which are wrapped around the bracket and the fork leg. How many? depends on the weight of the fabric you are useing (maybe its UD) it also depends on the resin type.
A couple of other things. The mechanical properties of the composite part will be affected by porosity content and resin content. You have tried to get rid of excess resin (i assume) with your tape. (which is not a bad idea) but just so you know, there is a product called shrink wrap. Wrap it around, heat with heat gun and it will shrink to give you a very good compression.
Resin type, what is the cure temperature and what temp do you intend to cure it at? if you dont reach the recommended temp for the right time you will not get the properties. Left in a cold garage to cure=not so good.
Galvanic corrosion, carbon in contact with AL is not so good. Probably ok for the time that this will last (:-) but longer term bonds will deteriorate.
Positioning on fork, well. You are attempting to modify a fork which has not been designed for this. In use you will be applying a significant and sometimes very aggressive and concentrated force, to a part of the fork which is probably highly loaded.
But I guess that anyway you are just doing it for fun and don't really intend to use it??
Posted : 25/01/2013 2:40 pm
[i]But I guess that anyway you are just doing it for fun and don't really intend to use it?? [/i]
I'd guess again...
Posted : 25/01/2013 2:41 pm
Gulp ! 😯
Posted : 25/01/2013 2:45 pm
cheif 9000 I thought you were a physicist?
I think Al is using low temp cure resin which is fine.
Posted : 25/01/2013 2:46 pm
Just having a think. The forces on the spacer will be acting in the direction of the blue line. This means the top will be in tension and the bottom will be in comprssion. The balsa will be squished unless the carbon has enough adhesion on the caliper mount to stop it rotating. The chief above my be into fiziks but from an engineering perspective, he's right.
Posted : 25/01/2013 3:03 pm
there is no argument that the forces are not all in tension, but there is more tension than if he had mounted it on the back of the caliper...
Seriously though: if you resolve your blue arrow (which is correct imho) into a horizontal and vertical component then you will have a force pulling to the right of the picture and a force going down. I don't think there is any compression on the balsa, but I think the downwards force will be appreciable and thats where it will fail.
The best way of doing this would have been to mount the caliper as close as possible to the fork leg, therby reducing the size of the downward component and keeping it mostly in tension.
Posted : 25/01/2013 3:31 pm
There's a bloke here wants to speak to you.....
Posted : 25/01/2013 3:38 pm
