A gubbins so you c...
[Closed] A gubbins so you can pump your shock up with your tyre pump?
Yesterday one of our group had a shock valve malfunction. Luckily he had a shock pump on him so could pump the shock up and leave it attached to get home.
I never carry a shock pump. So is there something that you can attach to a tyre pump so you can pump your shock in an emergency?
Posted : 29/08/2016 11:06 pm
A tyre pump is high volume, low pressure. A shock pump is low volume, high pressure. Difficult to get one pump to do both, unless.....
https://www.specialized.com/mt/en/accessories/air-tool-shock-frame-pump/105461
Posted : 29/08/2016 11:09 pm
Wouldn't a normal pump fit anyway? Although I doubt you would get the required pressure.
Normal pump will let all the air out when you disconnect it...
This double ones will take about a year to pump up a tyre, there is a reason they make different pumps
Posted : 29/08/2016 11:10 pm
You can use a shock pump on your tyres but as said the pressure would be too much for it to cope with. There was an ews story about Graves I think using a co2 inflator on his fork after a problem. Not recommended unless you have a sponsor nearby
Posted : 29/08/2016 11:12 pm
and then not really work on either your tyres or your shocks
I always carry mine on a group rde as someone will have a pump
Never get why we all go out with 23 multi tools and no variety of equipment just in case
I carry a mech and a shock pump
Possibly a tyre if really rocky
Posted : 29/08/2016 11:14 pm
Here's another combination pump
http://www.chainreactioncycles.com/airwave-dual-tyre-shock-pump/rp-prod126128
I have an old version of the Specialized Air tool and it's still going strong.
yes but they are all essentially a shck pump that in an emergency can pump your tyre if you have three hours to kill ๐Ÿ˜‰
Bit like those roadie micro pumps they are small but near useless when in operation
IMHO there is no point having a pump that does not really do the job when you ask it to so i would always take the weight penalty and take both if solo and i cared
Posted : 29/08/2016 11:39 pm
I did manage to do a maxxis dh tube on 26 with a shock pump and it didn't take as long as you would think. These days co2 and tubeless takes care of most of my issues that end. The only time I carry a shock pump is when I'm on a trip somewhere that I might want to tweak the bike.
It's one of the nice things about modern bikes they kind of work a bit better ๐Ÿ™‚
Posted : 29/08/2016 11:58 pm
A shock pump weighs next to nothing . Why would you not carry one ?
Posted : 30/08/2016 12:27 am
nope, that noise you hear is the high pressure air coming out of the gubbins external to the valve.
Posted : 30/08/2016 1:52 am
Lezyne pump with a schrader hose?
Posted : 30/08/2016 6:26 am
Next to nothing ? Clearly you and I(and physics) have different definitions of nothing
And they are awkward shaped.
Posted : 30/08/2016 6:33 am
I have the older version of the Specialised Air Tool...its a not a shock pump pretending to be a tyre pump, its better than that. You can choose to pump with the large volume cylinder or the small volume cylinder.
However, its fairly big, bulky, and too easy to accidentally 'change mode' during use, rather annoying when you are reinflating a tyre and have to keep stopping to 'close' the small volume section.
Mine did seem rather loose, perhaps the newer version has a more positive switch.
Posted : 30/08/2016 6:36 am
Blackburn Toolmanator 16 had a shock pump, seems to be still available at some retailers.
l.e. There's also [url= https://www.topeak.com/global/en/products/Pumps/353-microshock ]Topeak Microshock[/url], claiming to be "The lightest, most compact suspension pump in the World."
Posted : 30/08/2016 6:52 am
This hardly ever happens though TBF, and it's probably just about the only thing you could fix with a shock pump if your rear shock fails.
probability, I suspect.
Posted : 30/08/2016 6:56 am
I had one of those two cylinder specialized pumps 10 years ago
It was crap at both tasks
Maybe the modern design has improved, I don't know.
Posted : 30/08/2016 10:31 am
I got a tiny Birzman shock pump on EBay, it's a brilliant little thing
Posted : 30/08/2016 10:38 am
I've got one of those (Blackburn Airstick 2 Stage) it's got me out of the sh*t 3 or 4 times in the past month or so.
Posted : 30/08/2016 10:54 am
Clearly you and I (and physics ) have a different definition of awkward shaped .
Posted : 30/08/2016 12:38 pm
