A couple of questio...
[Closed] A couple of questions about moving from SS to 1x9...
Folks,
I think I'm going to move from SS to 1x9 for my trip to the Lakes later this month, but I've ridden without gears for so long I'm a bit out of the loop regarding the process. My frame doesn't have ISCG mounts, so what type of tensioner would I need? I see Superstar have a fairly cheap one - is it any good? And any other tips?
EDIT: Forgot to mention, I use a HT2 BB. Does this mean I replace the space left by the removal of the drive-side plastic spacers with a chain-device?
I'm frigging clueless...
Posted : 08/08/2011 4:50 pm
You can either use a full chain device for which you can get some that replace the HT2 spacer. Or you can use just a top chain guide device, like the Superstar, ethirteen XCX or MRP 1x.
Which one will be appropriate for you depends on your gnar level.
Posted : 08/08/2011 5:08 pm
There is [u]no[/u] gnar level. I don't even have a gnarometer.
Posted : 08/08/2011 6:00 pm
