Okay, i know Jtek used to make little ratio pullys, however due to health issues he has now shut down.
I want to use Sram TT 10speed bar end shifters and an X.0 deralliur, however iv only just bought a 9 speed TI cassette and chain. i really cant affored another £xxx on another chain and cassette.
I belive on shimanos there is a way to reroute the cable to allow different ratios
Are there any other methods or anything similar to shimanos?
Thanks
Craig
Not quite sure what you are asking, but if you have SRAM shifters and an X0 mech, they will work together. Cassette & chain make isn't important......
are the sram TT shifters 10 speed?
take it the TT shifters are 10 speed
you could experiment with the cable clamp but i suspect tha you'll never get truly slick shifting
the shimano workaround is a fluke of chance really
Hi yeah, maybe i should have explained myself better.
The TTshifter are 10speed, and the cassette is 9 speed.
I wasnt sure if there any other companys making ratio changing pullys out there?
Thanks
Craig
Have a look at this:
[url] http://www.ctc.org.uk/desktopdefault.aspx?tabid=3946 [/url]
Bugger, just noticed that it doesn't have SRAM 10 speed on there.
Anyway, as above, chances are that 10 speed SRAM shifters won't work with 9 speed SRAM cassette and mechs.
Thanks Clubber, Yeah it seems more difficult with Sram.
Craig
I assume the SRAM shifters can't be switched to friction rather than index?
They are the new style R2C ones 🙂
So unfortunatly not.
Why on earth are you using TT shifters on an MTB?
Or... why are you using an MTB mech on a TT bike?
It won't work properly. Simple.
Reason: i need to mount my shifter on the frame, im going to machine a plate to mount it to the bottole mount.
TT bar ends are perfect for mounting like this. i can machine a plate with a 45 degree block to mount to.
Im using a gyro up front you see and dont wanna go single speed.
Craig
For all that hassle, I reckon it'd be easier just to get an old handlebar, cut of a section approx 15cm long, flatten/crush the tube at one end, bend that approx 90 degrees, drill a hole in the flattened bit and then bolt it onto the bottle cage mount. Then fit a normal shifter to the handlebar stump. Job done and not having to bodge a system with a very espensive shifter.
This is on your Kona which, for some totally unbeknown reason, wasn't liked on Pink Bike?
Edit: as an aside... why are you running a Gyro on an MTB, and how do you have brakes?
If you must use TT shifters, just get some Shimano friction jobbies.
Everythign about this Kona sounds awe-inspiring. Just imagine: a Kona with TT shifters attached to the bottle bosses and a gyro! How could it be anything but ACE? 8)
Is this not a Kona Dawg though, hardly a jump bike. I'm certainly intrigued...
came up a bit short on the skirting board there...
And it starts.
Well its a DJ/Street, thats what im building it up as.
Using Hydro Gyro will allow me to do bar spins.
Its a Kona Chute
Well you were warned... Lets see a photo then!
Here's an example of the frame mounted shifter
[url] http://www.pinkbike.com/photo/2153033/ [/url]
and here (last pic)
[url] http://www.pinkbike.com/news/Jack-Fogelquist-banshee-2009.html [/url]
Am I missing something? Is 10speed XX not the same ratio lever pull as 9spd XO? So you'll just have a redundant stop if you use a 9spd XO mech?
You could avoid all this by holding the gear cable in your teeth. Bit of gaffa tape and you enamel will be fine.
Anotherdeadhero. Sorry i wasnt aware that a TT10speed had same pull radio as a 9speed X.0??? if thats the case. thats perfect!
However, whats the problem with me wanting to use a hydro gyro on a jump bike?
I don't know that it is, thats why I was asking ...
I have no problem with you using a gyro on your bike, it is your bike, you can spaff it up any which way you please.
That wasnt aimed at you.
I thought you was stating itwas, you got my hopes up then 🙁
How about just using non RTC 9spd TT shifters? Its a bodge anyway.
That was the 2nd plan.
What do you mean 'a bodge?'
No disrespect but i am, literally trying as hard as i can with this bike. The parts will be machined to a profesinoal standard(spelling?)
Craig
As far as I know, all SRAM shifters (maybe not the roadie hoods, dunno) use 1:1 ratio shifting, so you'll just have a redundant shift, but you could probably tension that out if you were really anal about it.
No no no no no... SRAM 10 speed cassettes are the same width as their 9 speed ones, with an extra cog, so every time you shift on a 9 speed set up, you'll be undershifting by 10% or so.
Why don't you just fit a cheap 10 speed road block to the bike? If it's a jump bike you're hardly going to be honking up hills presumably?
Ok, so it'll be a good bodge, but you're still doing something with a piece of equipment that wasn't the original intension behind the product.
Stop being so touchy.
That may be true, but the actual [u]amount[/u] of cable pull here is important, not the ratio.
Looks like a 9spd non RTC shifter then.
I think the way forward here is goign to be non R2C friction shifter.
They dont make 9speed TT's.
I appreciate the help, i think thats the only way forward here.
Other than spending weeks in making a ratio pully...which i dont fancy.
Craig
Or you could swap/buy the 9spd stuff you bought in error for some 10spd stuff.
It looks like what my old man would have called "heath robinson"
Unfortunatly my 9speed stuff is used so i cant take it back.
Reguardign the Heath Robinson comment: 😆 - true...but i cant help myself
Craig
Should be easy to sell on nearly new 9sp cassette & chain, the RTC shifter sounds like a neat way of doing it to me and would certainly be different to what most people have...
Aha, I see, learn something new everyday.
