9-42 10 Speed Casse...
[Closed] 9-42 10 Speed Cassette from Leonardi Racing
9-11-13-15-18-21-24-29-35-42 from Leonardi Racing
for XD freehubs
might be useful for some
[URL= http://i1272.photobucket.com/albums/y394/dansipods2/1479452_395961330535817_242050849_n_zpseaedc165.jp g" target="_blank">http://i1272.photobucket.com/albums/y394/dansipods2/1479452_395961330535817_242050849_n_zpseaedc165.jp g"/> [/IMG][/URL]
[URL= http://i1272.photobucket.com/albums/y394/dansipods2/960221_395961540535796_489700156_n_zpsa3d2467f.jp g" target="_blank">http://i1272.photobucket.com/albums/y394/dansipods2/960221_395961540535796_489700156_n_zpsa3d2467f.jp g"/> [/IMG][/URL]
Posted : 05/12/2013 8:37 pm
Nope, I just don't get it sorry. Is the intention for it to be used as 1* 10 but retain the range of a triple?
Posted : 05/12/2013 8:48 pm
that's what people will say about any of the 3 biggest sprockets
Posted : 05/12/2013 8:53 pm
Why would you get a xD free hub and then run it 1x10?
Too much range there for 10 speed, the last 2 rings jump 6 then 7
For me the ideal 10 speed should go 11,13,15,18,21,24,29,34,39 then we don't need 11 speed so come on shimano sort it out?
Ps this is for 1x10 users, this with a 34t or 36t front would be ideal.
Posted : 05/12/2013 8:54 pm
cyclistm
you missed the whole xx1 movement then?
This looks expensive and fragile. If it fitted a normal hub I'd give it a bash, but it won't so I won't.
I'm definitely going to get one of those 42 tooth cogs that was featured on here a few days ago however. For 99% of my riding a 36 cog is fine, but I know that I'd like to have the bail out gear available to me if I need it
Posted : 05/12/2013 9:10 pm
It does [i]look[/i] very nice….
But, I wonder at what point in time will some bike industry marketeer (or WMB/MBR journo's) start telling us that to avoid the multiple gear changes to cope with instant gradient changes,blah blah blah, reduce rear wheel rotating mass blah blah, get the weight more evenly distributed in the lowest most central point of the bike blah blah blah, that the answer is in fact a quadruple front ring set-up!!????
2016 ish I reckon…. 😉
Posted : 05/12/2013 9:17 pm
Like it - Leonardi are doing some really cool stuff and pushing the boundaries. Logic I guess is that lots of manufacturers now have a XD freehub body for not a lot of money so you can get the XX1 range for just a cassette and body, rather than new drivetrain.
We need to see more of this - little firms trying out new things, tweaking what we think is possible, generally tinkering.
Posted : 05/12/2013 9:43 pm
yup
Posted : 05/12/2013 9:47 pm
I'd would be cursing the huge jumps between gears constantly if I used one of those. A 10 speed 11-34 is bad enough.
Posted : 05/12/2013 10:47 pm
What's an XD freehub?
Posted : 06/12/2013 2:16 am
 JoeG
slackalice - Member
It does look very nice….
2016 ish I reckon….
1988, actually. 😉
Posted : 06/12/2013 2:23 am
 DanW
Nice product, thanks for posting.
If it isn't any cheaper than an XX1 cassette then the attractions diminish greatly IMO- XX1 rear mechs and shifters can be found at decent prices but the cassette is so damn expensive everywhere! If the cassettes are the same price I'd be inclined to spend that bit extra and get an XX1 shifter and mech to go with the cassette have a much better spread of gearing done properly.
Posted : 06/12/2013 2:41 am
would be interested in trying the thing just to see the gaps and how they feel. Also to see how a normal Rear Mech plays with the big steps, part of me wonders how it will shift up and down those big steps.
Great to see someone doing something good, a cassette is a lot easier to make than a shifter and mech so the small guys can have a go. Seems like Shimano are not sure where to go next and are waiting to see if 11sp is popular enough to [s]copy[/s] develop
Posted : 06/12/2013 2:45 am
http://www.chainreactioncycles.com/au/en/s?q=hope+freehub&ss=2481
and considering the price for the standard is the same as the XD from hope it's not going to be that long before we have some more versions about. Maybe time for the hope freehub cassette to finally arrive
Posted : 06/12/2013 2:50 am
9 tooth sprocket ? excellent with a 55 tooth ring for time trialling +162 inch gear !!
Posted : 06/12/2013 8:37 am
Hey good shout JoeG! A bargain at $49.95 too! 😀
Posted : 06/12/2013 8:38 am
The XD freehub design removes the damage that normal cassettes always do to alloy freehubs. Making a 10spd cassette to fit the XD freehub is really cool 🙂
Not so sure about the 9 tooth as I've found the 10 tooth on XX1 to be a bit "lumpy" under power; not that I power much when in that gear as its mostly required only for road sections (XX1 is on my All Mountain bike).
Posted : 06/12/2013 8:56 am
 mos
I think it would have been better to do a 10-40T one to keep the gaps a bit smaller & kind of make it an amalgamation between the XX1 10T bottom end & the LR 40T top end that they already do.
Posted : 06/12/2013 9:58 am
Not long before it happens now...... Shortly after we hit 1x12 someone will invent a thick/thin chainring that shifts, andwork out that if we were to put another chainring at the front and a slim 6 speed cassette at the back, we'd have a stronger wheel with less dish, closer ratios and less weight, and hey presto! We'd be back on 6 speed of off 1987 and have gone full circle
Posted : 06/12/2013 10:01 am
Tsk, that's wheels for you 🙂
Posted : 06/12/2013 10:13 am
http://cicloappuntamenti.forumfree.it/?t=67585356&st=15#entry547898523
Posted : 07/12/2013 11:22 am
That looks rubbish.
2x10 is fine for me and my shifting works well. Or if you really want wide ratios and 1x something buy SRAM X1 or X01. Or go 1x10 with a 36 and build up those puny legs.
Posted : 07/12/2013 11:31 am
Nice. I'd happily replace my General Lee adapter with that.
Posted : 07/12/2013 12:10 pm
It still onbeing tested, will be released soon.
For now only the revised General Lee that still works fine
http://www.ebay.co.uk/itm/General-Lee-11-42-Cassette-Sprockets-Kit-SRAM-SHIMANO-Sram-XX1-Alternative-/201079103274?pt=UK_sportsleisure_cycling_bikeparts_SR&var=&hash=item2ed13f9f2a
Posted : 28/04/2014 11:23 pm
General Lee 942 Cassette - Sram XX1 alternative NEW MODEL
Has just been release in Expobici - Padova
It's already available for sale
9.42T
10 Speed
XD Hub compatibility
Aluminium 7075 T6 CNC machined
SRAM Type 2 Derraileur long cage required
Also available in 9.38 Version: 9-11-13-15-17-20-23-27-32-38 (Compatible with Sram and Shimano Derraileurs)
Available on ebay.com
Posted : 03/10/2014 2:59 am
Aluminium. So like every other one before it it'll be flexy, shift badly and wear out in seconds.
Posted : 03/10/2014 7:00 am
Only the first 3 cogs are aluminium, the cassette body is made of steel
Posted : 03/10/2014 11:29 am
 D0NK
hmm dunno, one thing I like about 10spd is it's a standard 9spd 11-32 cassette with a 36 bolted on*, natural progresison to 11spd to bolt on a 42, I didn't like the jumps on a 9spd 11-34. 10spd 11-39 would be a nice option to atleast try tho.
*do not see much point in 10spd 11-32/34 cassettes myself, but who knows maybe some people are even more sensitive to gear jumps than me.
Posted : 03/10/2014 11:48 am
Ah ok, I saw "aluminium" in the spec and started twitching! Still can't see that shifting well or lasting, but fair play for doing it!
I've also just seen the price - $400 on eBay, so more than an XX1 cassette.
Where's that shitty stick I use to not touch things like this!?
Posted : 03/10/2014 11:49 am
I think Hora's using it to beat off the burds.
But you can borrow my bargepole if you'd like to use the correct tool for the job
Posted : 03/10/2014 12:51 pm
It's not cheap, but considering you don't have to buy XX1 trigger, cranks, derraileur, etc... it might be an option to think about
About shifting, I'll let you know when it arrives and go for a ride
Posted : 03/10/2014 1:15 pm
"SRAM Type 2 Dérailleur long cage required" - does that mean Shimano incompatible, for some reason?
Posted : 03/10/2014 1:38 pm
personally I would think that if you were going to have a 9t sprocket you'd pitch it at something like a 24 or 26t chainring and run perhaps 9-30t which is about the same as a 11-42 while not having to botch your mech to get to the 42.
oh, the weigh saving too, of course (I've not got over the 90's)
Now if we could get a Capreo freehub on a disc hubshell....
Posted : 03/10/2014 1:47 pm
9.42 cassette was developed and tuned for Sram derraileurs, I think it has to do with shifting performance
With 9.38 both can be used Shimano or Sram
Posted : 03/10/2014 6:14 pm
You don't need the cranks anyway, but yes, you save the cost of the shifter and rear mech.
Posted : 03/10/2014 7:30 pm
