700c/29er wheels on...
[Closed] 700c/29er wheels on 26 MTB
[#5172990]
Hey all
Wanted to run something past everyone. Am thinking of getting some larger wheels for Whyte hardtail so can use on events with less technical stuff (can't afford a CX bike) and get much better roll.
My bike has discs so don't have rim width + brakes problems. Have measured axle to suspension cross-over and should be able to fit a wheel with final diameter under 680mm-690mm. Assuming 29er wheels are same width as my current 26 wheels. So...
- Anyone know any CX 700c/29er tyres with diameter under 690mm? I've been using widely spread theory of 'final diameter = stated diameter + 2 x stated width'.
- Have I missed an obvious point? I'm pretty new to customising at this level so am probably ignoring something crucial!
Any thoughts appreciated
Thansk
Nick
Posted : 20/05/2013 1:45 pm
sounds like what you need is 650b...
Posted : 20/05/2013 1:47 pm
Yeah, thought about them but I'm really after maximum roll rather than something inbetween. I think I can fit a 29er wheel in with low-depth tyre - reckon that extra 1 1/2 inch will make some difference on speed.
Posted : 20/05/2013 1:54 pm
Seen this done quite a few times, although mainly to convert MTBs for road use. 700c wheels with skinny tyres are going to be a similar diameter to 26" knobblies so it probably won't mess up the handling all that much.
Remember rear hub spacing may be different for 700C wheels though.
Posted : 20/05/2013 2:17 pm
This is a pic of my Tinbred with 700c rims (built onto MTB hubs) and 35mm cyclo cross tyre...
Posted : 20/05/2013 2:54 pm
I've put CX wheels in an MTB, it worked, but it screwed the handling up a bit and wasn't really lots faster than a 26" semi slick.
You can get 95% of the benefits just by changing the tyres and pumping them up a bit.
Posted : 20/05/2013 2:57 pm
You know what, I hadn't considered that as my current Crossmarks are almost maximum diameter for my forks then I won't really be gaining any extra wheel size from going bigger wheel but lower profile tyres. Seems obvious now. Maybe I'll try semi slicks.
Anyone got a recommendations on really thick (to increase diameter) semi-slick MTB tyres?
Posted : 20/05/2013 3:05 pm
Schwalbe Big Apples? I've got a set (in 700c) and really rate them, comfortable, reasonably fast rolling.
Posted : 20/05/2013 3:12 pm
I have an old Carrerra Subway commuter frame that I wanted to build as a commuter with some spare 29er wheels, but I cant fit a 29x1.5" slick in the rear. So I'd try & find out for sure before making the assumption that it will fit. To be fair though, the Carrerra is a Commuter so wasnt designed for 26" knobblies.
I'm thinking of [i]modifying[/i] the Carrerra frame slightly...with a hammer. 😉
Posted : 20/05/2013 4:10 pm
My Cannondale Bad Boy Frankenbike can just fit a 700x40 tyre with sod all clearance. I'd go 650b in the rear if I had the option again.
Front was no problem as I had 29er forks.
I'm also running a 50mm stem and drop bars just before you think it can't sound any worse. It's [url= http://flic.kr/p/bK24Q2 ]here[/url]
Posted : 20/05/2013 5:07 pm
Looks pretty cool to me! What tyres are they?
Think I'm gonna need something that can handle a little more mud than the Big Apples...
Posted : 20/05/2013 5:52 pm
You could grind away some of your fork brace and any bits of the bottom bracket or seat-stay brace that fouls a big 29er tyre and increase your speed that way? Most of those so-called 'structural parts' are only there because smaller wheels require more bracing,, a proper 29er will be so much faster that it won't need that stuff. I think...
Disclaimer: I'm not an engineer, just a free-thinking bike visionary.
Posted : 20/05/2013 6:42 pm
Specialized Borough, I got them for less than a ten era piece
Posted : 20/05/2013 7:35 pm
