6 speed trigger shi...
[Closed] 6 speed trigger shifter, is there such a thing? Or change to 7 speed?
I have picked up a really good condition second hand specialized hotrock 20 for our daughter.
https://photos.app.goo.gl/hZSntP2gEnTPjDEH9
She is getting a bit big for the spesh idlejon gave her, that will be put by ready for our youngest. It has a 6 speed freewheel by the looks of it and a revoshift. I have searched but can't find one, is there a 6 speed trigger shifter available anywhere or should I change it to 7 speed? Where would be best to get any of the parts from?
Thanks
Posted : 23/11/2018 5:11 pm
Stick a seven speed on there and adjust it so that it can't shift into "1" on the display?
Posted : 23/11/2018 7:38 pm
Oh, but make sure she can use the trigfers.ย  My daughter doesn't have the reach with her thumb to operate triggers,. And wanted twist shiftrrs
Posted : 23/11/2018 7:40 pm
Both points I hadn't thought of, thanks. Will hang on a bit til she can have a good go with it.
Posted : 23/11/2018 7:48 pm
General opinion seems to be that the Revo shift needs spotless cabling to work effectively though.ย  Triggers tend to be more forgiving.
Posted : 23/11/2018 8:02 pm
I've had grip shifts before, but much prefer triggers. Thought the revoshift looked a bit bulky and she is near enough 6 now so has small hands, hence the thought. Will see how it goes. Thanks again.
Posted : 23/11/2018 8:05 pm
The SRAM MRX shifters tend to need good cables otherwise it can get very stiff, Revoshift is a lot more tolerant.
Anyway, if you decide to go for triggers just let me know, I have loads of trigger shifters and 7 speed freewheels you can have if you need them.
Posted : 23/11/2018 8:14 pm
Nice new bike!
As above, trigger shifter lever travel and resistance can be too much for small hands.
Posted : 23/11/2018 8:31 pm
My kids experience was the opposite - couldn't operate a twist shift but had no such problems with a trigger shifter. As far as parts go look for something like an Altus shifter and there are plenty of choices for a 7 speed cassette. If you are going to fit a 7 speed then look for the ones with the 34t bail out sprocket, can be a lifesaver for tired legs
Posted : 23/11/2018 9:04 pm
