6 bolt rotors - do ...
[Closed] 6 bolt rotors - do you use threadlock?
As the title really - only ever used centre lock - do I need to put threadlock when installing my rotors?
Cheers,
J
Posted : 18/09/2009 12:52 pm
The Shimano-supplied bolts already have threadlock on them
Posted : 18/09/2009 12:53 pm
All the bolts I've used have blue threadlock on them already....
Posted : 18/09/2009 12:55 pm
cool - that's easy then.
off to order some bolts.
๐Ÿ™‚
Posted : 18/09/2009 1:15 pm
mmmm, I had one seize into a hub and that stripped the thread out of the hub, always done the anti threadlock thing since then and put grease on them..
Posted : 18/09/2009 1:20 pm
Avid bolts have threadlock on them when they come too.
Posted : 18/09/2009 1:44 pm
..Hope's do too
Posted : 18/09/2009 2:37 pm
Yes you should realy use locktite but only use the blue 248 mediun strength NOT the red 222.
Posted : 18/09/2009 5:58 pm
Mind you, 6 bolts on brake rotors for bicycles is massive overkill anyway, so threadlock on them as well...
Posted : 18/09/2009 6:07 pm
I used grease last time, damn things keep coming loose ๐Ÿ™‚
If your multi-tool has a torx attachment, get the torx rotor bolts as they are much harder to round off.
Posted : 18/09/2009 6:09 pm
baznav, what's wrong with 222? I've been using that on bikes for years without issue. It's a low strength product so is perfect for bolts with soft heads (like rotor bolts)
Posted : 18/09/2009 6:12 pm
instead of threadlock I use a loctite retainer 638 or similar. Put a blob of this under the head of the fastener. works just as well and less likely to shear a bolt in the future when undoing...
works for car conrold bolts as well and does not modify torque readings
Posted : 20/09/2009 10:35 am
