50t 1x11 setup
[Closed] 50t 1x11 setup
I’ve got an Orange Alpine Five.  I have an XTR rear mech 50t Sunrace cassette, with an Absolute Black 34t oval front ring and a Goat tooth hanger.  currently if I click to change from 2nd to 3rd nothing happens click again and it jumps to 4th and I shift down to 3rd.  If I screw the B tension screw back out it sorts this shifting issue out…. however when I get to 11th there is loads of slack in the chain.  In 1st there is no slack whatsoever.
Any ideas what I can do?
Posted : 03/08/2018 5:14 pm
Chain length?
And the usual hanger alignment, new cables etc.
Posted : 03/08/2018 5:16 pm
I use one of these: https://garbaruk.com/products/rear-derailleur-cages.html?limit=all
with one of their 50T cassettes (11 Speed setup, XT Mech). Not had any problems and the longer cage takes up the slack well.
Posted : 03/08/2018 5:17 pm
Chain length can't be any shorter as it is already at max stretch on the 50t, don't think it's hanger alignment as it shifts when the b screw is wound out and I've put a new cable in.
Posted : 03/08/2018 5:19 pm
Hmm, no idea then. 🙁
The chain couldn't be any shorter even with the smaller B gap?
Posted : 03/08/2018 5:36 pm
 poah
I put a sunrace 11-50t on my son's scout with a GS 11sp XT mech.  All I had to do is turn the B screw a bit and adjusted the wire tension,
Posted : 03/08/2018 5:38 pm
One Up shark cage might be worth a go if you've prove that standard kit and the goat link isn't enough.
However, have you checked the hanger alignment?
Posted : 03/08/2018 5:50 pm
I use a sram GX eagle mech with my hope 10-48, works a treat with 11sp sram shifter
Posted : 03/08/2018 6:55 pm
