456 ti pic request ...
[Closed] 456 ti pic request and rotor size question
I've taken the plunge and ordered a 456 ti. Please can you ti owners post some pics of yours for build ideas.
Also, what max size rotor can I use?
Ta
Matt
Posted : 27/12/2013 7:30 pm
 br
[i]Also, what max size rotor can I use?[/i]
203mm if you really want to, but never needed more than a 160mm and tbh when I lived down south, 140mm was fine.
Posted : 27/12/2013 8:20 pm
This is mine a 2012 van nic, current build DT XXM 120 forks, American Classic wheels, XT 1x10 drivetrain with XT brakes, use sumo ti post, 60mm turbine stem with kingdoms 730 wide flat ti bars, comes in at 23.5 lbs and rides lovely!!!!
Posted : 27/12/2013 8:42 pm
Thanks for the info on rotor size, I've got a 183mm that I can use.
Nice bike Jonny, is that a 16" or 18"? I've got 2x10 that I'm thinking of transferring, are you 1x10 or 1x11??
Posted : 28/12/2013 10:56 am
Johnie
how do you find the 120 fork for you on the 456?
Posted : 28/12/2013 11:11 am
Lester
Just right, I did ride it with some dp rev's, but found the 120 setting better, so that's why I put the 120 dt's on
Rotor size I'm on 160 front and back ice tech with finned pads and find them superb
It's a 16" (I' m 5'8") and 1x10
Posted : 28/12/2013 12:55 pm
Johny
ive got dts on mine 150Exm and i wouldnt have thought to reduce it to 120 on the 456, i might try some 120s and see how i get on,
i run 203 on the front and 160s on the back, but i way 220 with all my kit on
Posted : 28/12/2013 12:59 pm
 Keva
here's my 456 with 130mm DTs
Posted : 28/12/2013 1:10 pm
