450mm a-c rigid for...
[Closed] 450mm a-c rigid for on an Inbred - ok?
 PJay
I've got an Inbred designed to take 100mm-130mm suspension forks and may switch to a rigid steel fork. On-One's own carbon rigids have a 440mm a-c measurement which I think is suposed to equate to 100mm sus. forks with sag. The fork I'm looking at is 450mm a-c, which is a bit higher. I'm currently running 100mm Rebas which I believe are tall for 100mm forks (around 470mm without sag, so possible 460-460 with sag).
Would I 450mm fork work well I get a bit confused with a-c heights and compression forces of sus. forks in relation to what a frame is designed to take? I don't want to bust the frame either!
Posted : 30/04/2009 3:53 pm
It'll be grand
Posted : 30/04/2009 3:55 pm
i would concur
Posted : 30/04/2009 4:28 pm
It will be fine. I recently changed to from 420 to 440mm on my old inbred, rides much better IMO.
Posted : 30/04/2009 7:28 pm
