44 front chain ring...
[Closed] 44 front chain rings. Can you "go" bigger?
I have an XTR chain set with a 44 front chain ring.
Is there a reason no one seems to make bigger rings?
Or does anyone make bigger rings and if so, can they be used at all? Do you need a long rear mech' or am I barking up the wrong tree here?
Posted : 06/08/2009 9:24 am
You can get a 46T for touring, why you'd want it on a normal MTB I'm not sure.
Posted : 06/08/2009 9:26 am
Mainly because there's no real need offroad - even top XC racers don't spin out a 44x11.
Back in the day, pre-compact when a cassette's smallest sprocket was a 12, 48s weren't uncommon but that's the same ratio.
You can get bigger rings nowadays still but they're not normal so you'll have to look a bit harder for them - companies like TA make them IIRC. Worth a look at SJS cycles too who sell them for touring (since you should only really need it that big for road riding).
A normal long mtb rear mech will be fine assuming you're not going silly and fitting a 52 or something.
Posted : 06/08/2009 9:28 am
 GW
think you want a roadbike mate. ๐Ÿ˜‰
Posted : 06/08/2009 9:30 am
Which generation of XTR? If it's M960 you're stuck, if it's M970 you can fit what you want in the way of a bigger one.
I've got a 40t big ring, and don't feel the need for bigger.
I run a 46 chainring (middleburn) on one of my bikes, I like it as I can get up some decent speeds but have big legs so it suits me.
[too slow]Ppl will be a long quote speed figures as to how silly it is to run even a 44 chainring as you 'just' won't go that fast for any distance.
Obviously they've never ridden with my m8 Jimmy, I need all the help I can get when trying to keep up (ok it's the flat midlands).
As for rear mech, no as long as you have a long cage one, you'll be fine.
48 chainring are also available but really are more suited for road usage.
Posted : 06/08/2009 9:32 am
Just how fast is your mate?!
I'm happy to quote figures ๐Ÿ™‚ I also have big legs ๐Ÿ™‚
44x11 would be comfortable even if you're grinding along at 70rpm cadence, producing a speed of 22mph (70/min x 4 (ratio) x 2.1m (approx circumference of 26" wheel) = 588m/min = 35.3km/h = 22mph). Up that to a more reasonable 80 cadence and the speed is 25mph!
So you're suggesting that your mate rides for extended periods at 22 to 25mph offroad? He needs to get on to British Cycling and tell them he's offering a guaranteed gold medal at the World Champs! ๐Ÿ™‚
Posted : 06/08/2009 9:46 am
he's a very fast road rider come mtb-er, what can I say, I find having the bigger ring helps to even things out.
You also need to bear in mind we have lots of long flat canal stretchs to get between trails, I like em and have replaced it once already.
Posted : 06/08/2009 10:06 am
Big legs = Speed ๐Ÿ™„
If that was the case there would be some really fast guys in my local McD's and KFC! ๐Ÿ˜†
Posted : 06/08/2009 10:11 am
z1ppy, it sounds to me like you need to learn to spin more rather than just stick a bigger chainring on ๐Ÿ™‚
Posted : 06/08/2009 10:13 am
Well, it's whatever works for you and if you like a 46 then fine. That answers the original post, yes you can go bigger.
I'm more interested in going smaller as I find a 44 too big. Mainly in terms of clearance, a 44 outer takes quite a bit of beating. I'm interested to know where njee20 got that 40T ring from? I quite fancy giving one of those a try!
Posted : 06/08/2009 10:17 am
maybe so, but I like it and will stick with it, and all I was doing was answering the OP without be-littleing the question, as per most replies on here.
Posted : 06/08/2009 10:18 am
Another question (possibly silly). How small can big chainrings go? I'm running 22/36/bash at the moment, which I quite like but wondering whether 22/32/38 or thereabouts might not make sense. I went double because I was mainly using the big ring to tension the chain downhill not because I needed a bash on there particularly.
ooooh get you! ๐Ÿ˜‰
Posted : 06/08/2009 10:22 am
I answered it too ๐Ÿ™‚
And just questioning the need isn't belittling unless you're a really sensitive soul,just trying to stop someone wasting money on something that they don't really need. Plus, the OP did actually ask if there was a reason why people don't have them!
Posted : 06/08/2009 10:27 am
As long as it's the latest iteration of XTR, otherwise you can't.
Posted : 06/08/2009 10:30 am
FWIW, I've recently gone to a 2x9 setup 24/36 and 11-34 - pretty much all the gears that I need for offroad (actually, and on road since I do spin ๐Ÿ™‚ )
If you have an XTR M960 you can get a 45t Rotor Q Ring to fit as oppossed to the standard 44t.
www.velotechservices.co.uk sell them.
Been replacing my old XTR rings on a few bikes with these, really like the apparently smoother pedalling action, particularly uphills.
Posted : 06/08/2009 11:57 am
you must live somewhere where riding is downhill...unless your far far stronger and faster than absalon who runs a 40t outer ring.Ring up phil dixon because im sure he'd like to see your big legs ;)maybe just practise pushing a smaller gear..its all over better for you.
Posted : 06/08/2009 12:02 pm
http://www.rotoruk.co.uk/qrings.html
Think I might give it a try for an event that's going to see quite a lot of fire trails in order to link a little single track along its 100 mile length.
I'd take the 29er which eats miles before breakfast, & then some, but for 13hrs in the saddle I am opting for the 26er which is a little more forgiving over long rides but has a number of damaged teeth on the 44 ring - so that was the reasoning for the post.
Not being a big spinner, I seem to prefer to press a slightly bigger gear/ring, just how I ride of late I think.
Cheers, and I'll post back and tell you how it works out, if I do buy it.
Posted : 06/08/2009 12:26 pm
Why is spinning better? I prefer pushing a bigger gear.
Posted : 06/08/2009 2:03 pm
Spinning's more efficient and your legs will hurt less at the end of a long ride. Requires more aerobic fitness (you'll feel more breathy) to get the best out of it though which is one reason why unfit people like to push big gears. Simples.
Posted : 06/08/2009 2:25 pm
You saying I'm unfit?
Posted : 06/08/2009 2:37 pm
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=40496 ]Deore goes up to 48. [/url]
Posted : 06/08/2009 2:38 pm
I think he is ๐Ÿ˜‰
Posted : 06/08/2009 2:39 pm
I'll let my riding do the talking, but I blew my freehub winning an uphill sprint last night.
Posted : 06/08/2009 2:45 pm
Willy waving will win no favours on here, neither will shoddy mechanics ๐Ÿ˜‰
Posted : 06/08/2009 2:48 pm
I recently put a road bike triple on my mtb 32/42/52
It was a tight squeeze for the chain stays, but with a few spins the chain rings dont scrape of the chain stays any more!
The reason i put this on, is because i use my mtb for chaingangs and i was seriously spinning out at 34mph and i could only hold that and not go any faster, so in tail wind/down hill sections when the speed went over that, i got dropped.
Now with 52x11 i have no problems, other than the extra weight when we hit the hills.
Ive had no other issues, other than putting 3 or 4 links back on the chain.
Posted : 06/08/2009 2:53 pm
Do you really notice that!? No I didn't think so.
That will only work if you have a 68mm b/b, and I'm not sure I like the idea of intentionally taking chunks out of ones chainstays! Each to their own though.
Posted : 06/08/2009 3:36 pm
I meant the extra weight of the 36lb mtb over the 17lb road bike!!!!!!!!!
Posted : 06/08/2009 3:49 pm
Aaah! That makes a lot more sense.
What on earth are you doing riding a 36lb MTB on road rides? How unpleasant.
Posted : 06/08/2009 3:55 pm
kiwijohn - Member
Lol - no I wasn't. I was simply saying that unfit people tend to push big gears because they find they get out of breath if they spin small gears fast. Fit people can mash big gears if they like, they'll just probably not be as quick as they could be if they trained themselves to spin ๐Ÿ˜‰
Posted : 06/08/2009 4:00 pm
I recall reading in one of Armstrong's 2x books about how Miguel Indurain pushed higher gears than he did, where he (Armstrong) would have a higher spinning cadence.
Nothing about "I'm fitter therefore I spin faster than that unfit bloke, Miguel".
Different methods, different bodies, different bikes and mechanics and strengths.
Anyhow, I'll let you know what an eliptical front 45 ring feels like as I've ordered one.
Zooooom!
Posted : 06/08/2009 9:11 pm
Anyone else remember the loony tunes massive rings by Paragon that used to be raced at Mammoth?
Posted : 06/08/2009 9:14 pm
More info:
http://www.highpath.net/cycles/ovals/01.html
Posted : 07/08/2009 12:28 am
 Aidy
We assume you only use the granny ring and 32/34 tooth sprocket, then?
Posted : 07/08/2009 12:57 am
The thing is a lot of the big gear pushing is a bit of a myth. Big Mig was a bit of a grinder, but a bit of a grinder for a pro roadies is generally spinning more than most non-pros and if you look at cadences most of the time, you'll see that the pro grinders are only really grinding when working really hard - eg most of the time in the peloton, they're actually spinning along at 90ish rpm.
Even Jan Ullrich, the consomethinge grinder typically used to spin at 80+ except when really under the cosh when he'd drop to 70ish.
It goes without saying that there's a cadence over which you become less efficient again ๐Ÿ™‚ However, if you really needed me to say that to understand, Aidy, over a certain cadence you start to get less efficient ๐Ÿ˜‰
Posted : 07/08/2009 8:55 am
Have you ever seen the cadence of team columbias' Bert Grabsch (World time trial champ). Looks almost painful to watch but seems to work for him....
Posted : 07/08/2009 9:04 am
Yes but again, only for a relatively short time (1hr max, typically more like 40mins) - he didn't ride the whole tour like that.
Posted : 07/08/2009 9:08 am
Well, it's fitted & felt a little strange at first.
SITS this w/end so I might be able to tell you how it rides.
However, the real test is on my local trails where I know timed sections intimately and will be able to give you a better indication of its performance - expect that maybe Wednesday.
Posted : 07/08/2009 8:14 pm
Ti29er - Member
I'd take the 29er which eats miles before breakfast, & then some, but [b]for 13hrs in the saddle[/b] I am opting for the 26er which is a little more forgiving over long rides but has a number of damaged teeth on the 44 ring - so that was the reasoning for the post.
there's a problem with that. seeing as the kielder enduro has a 12 hour time limit!!
Posted : 07/08/2009 8:29 pm
"The Bonty lap was 8 miles long, so you should really have done around 12-14 laps during the race (say 13 for arguement's sake - Tim). Bear in mind, to finish the Montane Kielder 100, you will have to maintain an average speed of 8mph to make all the check points by the cut off times."
13 x 8 = 104.
Sara @ SIP-Events
Posted : 07/08/2009 11:28 pm
I don't understand how you can realistically have timed sections on an off-road route, far too many variables for it to mean anything!
FWIW my 13 laps at 24/12 was 108 miles. What's the terrain like on the Kielder 100, is it lots of fireroad? I wouldn't have thought that many people would finish a tough 100 mile loop in 12 hours frankly!
Posted : 07/08/2009 11:43 pm
EGG Rings? they did/still do make custom chainrings
Posted : 08/08/2009 12:20 am
