42/40 tooth 10 spee...
[Closed] 42/40 tooth 10 speed shimano rear mech.
Which ones can I use? Lots of them say 36 t max.
Posted : 22/11/2017 9:25 pm
M6000 Deore (GS version)
Posted : 22/11/2017 9:29 pm
11 Speed M7000 or M8000 medium cage work best.
Posted : 22/11/2017 9:34 pm
Yes 11 speed not 10.
And that works ok with 10 speed shifters?
Posted : 22/11/2017 9:36 pm
Member your chain might be a bit short if changing from an older set up, so new chain would be a good idea.
It was you who posted a pic of mech stretched almost up to the chainstay wasn't it? yeah don't do that.
Posted : 22/11/2017 9:37 pm
Yup perfectly better than 10 speed with rad cage.
Posted : 22/11/2017 9:38 pm
10spd shadow xt m785 works fine with a sunrace 42t on one of my bikes but on the other the same set up needs a wolf tooth extender thingy.
Worth the effort though. I've never ridden an 11spd but I've saved a bunch of cash not upgrading everything!
Edit - it's called a goat link! Took a while but i got there in the end...
Posted : 22/11/2017 10:09 pm
This......
Posted : 22/11/2017 10:13 pm
You might need to take out the small washer under the B screw to get the cage wound out enough, or stick a longer screw in there to clear. I had to with an SLX and XT Long Cage Mech and a 11-42T
Posted : 24/11/2017 5:35 pm
Mine (11-42t) is working OK with an older XT 10 speed Shadow (no clutch) - b-screw wound pretty much all the way in.
Posted : 24/11/2017 5:58 pm
