40mm (ish) riser, 3...
[Closed] 40mm (ish) riser, 35mm diam - what's available?
I currently have a 20mm rise bar and would like to try a higher position but the stem is at the limit on the steerer with 25mm of spacers under so am looking for a higher rise bar that will allow a bit of experimentation and a bit less spacer.
Criteria: 760 min width, 35mm clamp 35-40mm rise, alloy, moderate sweep about 9-10 degrees not much more than £60. SO far I've found:
Renthal Fatbar
RaceFace Turbine R
Burgtec Ridewide (30 rise)
anything else I've missed that isn't astronomically expensive?
Thanks internet
Posted : 15/01/2019 12:09 pm
I know this is frowned on but I think i could sell you a Chromag BZA Carbon (35mm rise IIRC) or Renthal (40mm Rise)....
Posted : 15/01/2019 12:17 pm
Renthal Fatbar 35 come in 40mm rise
Renthal, at 760mm you can get the Fatbar Lite. I have just done the same, moved to a 40mm rise Renthal from a lower rise, not ridden it yet but looking forward to it!
Posted : 15/01/2019 1:21 pm
Burgtec, josh bryceland special edition bars, 38mm rise.
I was thinking similar and went for some renthal v2 40mm rise @ £52 from Tweeks however they were 31.8mm diameter.
Posted : 15/01/2019 5:41 pm
Yes, the Fatbar Lite is the one for that width. Really nice bar!
Posted : 15/01/2019 6:41 pm
Cheers,. Yes the fatbar seems the best choice, surprising there's so little above the 20mm rise mark
Posted : 15/01/2019 8:12 pm
