3D printing of a bi...
[Closed] 3D printing of a bike part.
Does anybody have any recommendations as to where I could get a part printed. I have the file ready to send/use.
Many thanks
Posted : 13/03/2022 2:51 pm
what are you wanting to print and in what material?
Posted : 13/03/2022 2:55 pm
Its a small seat tube mounted mud guard thing, designed specifically for the frame I have. Material some sort of hard wearing/rigid plastic.
Posted : 13/03/2022 3:00 pm
https://www.thingiverse.com/thing:4944925/files
Posted : 13/03/2022 3:01 pm
Maybe in tpu then...
I normally recommend 3D people UK, mainly because it was founded by a couple of my ex students. But they have moved on a bit and might not be into one off quite like they were.
Posted : 13/03/2022 3:03 pm
If you've got a step file just upload to, eg, Protolabs, and you'll get an immediate quote, and you can select what material. I've used them for years and always good results, but I don't have to pay myself!
Posted : 13/03/2022 3:10 pm
For that application I'd recommend SLS or MJF PA12 Nylon. We don't print one offs for individuals but there are a few instant quote bureaus that will although there is often a minimum order value.
Posted : 13/03/2022 3:40 pm
I used SGD 3D to print a few of these Shimano derailleur cage locks - https://www.thingiverse.com/thing:4668717
Nothing else came close for an efficient part for a small quantity - many had a high setup charge, minimum order value, or expensive delivery.
Posted : 13/03/2022 4:40 pm
Thank you all.
Posted : 13/03/2022 4:53 pm
@shredder
PM me and I'll see what I can do.
It will be PLA so probably won't be massively tough, but I'll take a look at the model & make an assessment.
I could probably rattle it off without too much bother, perhaps just postage to pay and a donation to a Ukrainian aid fund...
If I look at the model and think it won't be tough enough to bother with I'll let you know.
Posted : 13/03/2022 7:44 pm
Might be worth trying polycarb, bit tougher than some. For SLS, you'll probably have high startup costs (from experience of trying to get a quote and now working with SlS parts)
Also have a look on 3D hubs, you'll be able to find a local company that can print or post your part, or at very least, give you a quote
Posted : 13/03/2022 11:24 pm
Try your local library? Several in Perthshire have 3d printers you can use for a nominal charge.
Posted : 14/03/2022 8:52 am
'Protolabs' or 'imaterialise' are both good for 3D printing.
Posted : 14/03/2022 8:54 am
I was going to suggest local library as well - my local one has just been updated and renovated and now has a technology room with 2 (or 3) 3d printers...I've no idea how to use them yet as I can't work out what I'm wanting to try and print, but from what I understand is you book time on the printer and you get on with it.
Posted : 14/03/2022 9:06 am
Have a look for a local maker space too, you might find the membership fee less than the cost of a one off part, and a group of people who are often willing to help.
Posted : 14/03/2022 9:14 am
I guess you don't want to spend too much so you need to find someone to help. FYI, Protolabs will charge £129 for one in ABS. (Probably not the material you want but an indication of how much a company will charge.)
Posted : 14/03/2022 10:42 am
I've used https://www.rigidprints.co.uk who didn't have daft set up costs.
Posted : 14/03/2022 1:55 pm
We have a couple at work. It’s only a basic nylon they use but if you send me the step file I can ask them to run one off for me.
Posted : 20/03/2022 6:50 pm
