Looking for a new 26" 36H rim. Love the stans flow rims but they don't do a 36H verion of it. so what can I re-lace onto my hope pro II hub?
Strong and similar weight to the flow <500g
21mm internal width
Very easy to get running tubeless.
I'm struggling to find anything in 36H apart from DH rims!
Anyone want to buy a 36H hope hub to build into a 29" flow ex rim?
Sell the wheel and start again.
Your 29" hope+flow is probably worth more than a 26er in today's climate, I'd have thought? Swapping rims is always an expensive affair unless you can do it all yourself, it's almost always cheaper just to buy/sell complete wheels (and that's before you worry about 32h/36h compatibility.
DT do the EX500 in 36 hole, that's ~28mm outer so must be 21mm+ internal I'd have thought. I've got the older 540s and never had any bother tublessing them.
Annoyingly their new EX471, 30mm outer, 470g rim only seems to come in 28h ๐
Or just miss some holes on the hub and use a 32 hole rim, works fine.
Ah good shout on that DT Swiss EX500. I'll look into that. otherwise the hub will be going for sale!
amedias - MemberAnnoyingly their new EX471, 30mm outer, 470g rim only seems to come in 28h
That's Aaron Gwin's "No tyre needed" rim, isn't it?
Expensive option but Lightbicycle'll drill for 36.
