getting a new [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=20677 ]Xt cassette[/url] and spotted a saving of £4 if I go for the 32.
Whats the pros and cons of of each?
Also does anyone know if you can fit a shimano freehub on a Sun Ringle DiscJockey rear hub?
cheers
depends if you want a bigger granny gear gear or not...
34t aka Saga gears
Using a 34t will generate lots of macho comments on here!
However, I run one and found the lower ratio really useful - infact I don't think Ive used the front granny ring since running a 34t rear.
34T every time for me.
34t and take off the granny ring to save weight...... if you want to be a bit niche
do you ever run out of gears climbing?
34 if you do
32 if you dont
a vote for 32 here
who cares, you can find another gear combo which does exactly the same ration. if you need 34 and granny you should be walking
I run a 36t front ring, and uses a 11-34 cassette. I rarely dip into granny, but had to the other night heading up Ben Cleuch. That climb is brutal and sustained.
The cassette will fit on your Ringle hub no problem.
34 fat-32 fit 34 here
sounds like a 32 to me.
running 2 plus bash upfront so dropping the granny might be a bit drastic.
TW - I know the cassette will fit, its the freehub I want to change, £50 for a ringle one or £28 for a shimano if it works. Cheers for your input though
cheers
32 for boys, 34 for girls - easy
Looks like coleman was right. Personally I would (and do) go for 32 lighter weight and closer ratios. Sometimes tho on the really steep long hills (walna scar, fremy edge, gatesgarth) I've really wished I'd gone for 34 but those kind of climbs are few and far between and yes if it gets to 22x34 you'd use less time and energy pushing but if you *must* clean stuff the 34 could make the difference.
Get the 32T. Make you ride like a man..
I train using a 32 and then race enduros with a 34 - extra weight but when tired those extra 2 teeth can make a difference.
34 every time mate its really good for long climbs I fing the grnny get less use on the front too!!
I have a 34 cassette and I find that middle ring and 34 is a nice steady climbing ratio.
Otherwise who gives a crap nob ends who go around counting gear ratios deserve a slap and anyone who gets off and walks up anything short of a vertical wall needs another slap its called mountain biking not getting off and pushing biking
tangobravo - Member
<sigh>
34. If you've never needed 22-34 then you haven't been riding steep enough hills.
[i]its called mountain biking not getting off and pushing biking [/i]
If you want to walk you should`ve taken the 4 legged best friend, not the 2 wheeled one!
[b]For those unfamiliar with the concept, this is called humour[/b]
PS im a downhiller, but i think its hilarious how defensive some of you are!
I see no pleasure in pedling very slowly up a hill, but if you do go for it! but 22-34 is bearly moving
A 22/34 gear ratio at 80 pedal revs per minute gives a speed of 4 mph
A 22/32 gear ratio at 80 pedal revs per minute gives a speed of 4.3 mph
The reason your bearly (sic) moving is because your not pedalling fast enough
cheers for all the info about the cassette.
anybody got any views on the freehub compatibility issue?
Whatever suits your riding. I use 32.
If you're climbing hills all day then sure a 34 will help.
