2x10 Shimano M785 C...
[Closed] 2x10 Shimano M785 Cranks - What's the smallest outer ring i can run?
Hi All,
I'm keen to drop my 38T outer chain ring down to a 36 / 34 / 32T ring. Race face seem to have 36 + 34T options but i'm not sure if they offer a true 2x10 outer ring in either size. also, will it effect my M785 2x10 Front mech if i drop sizes?
Any input welcome, thanks
Posted : 09/08/2013 6:57 pm
I swapped out a 32t Shimano XT FCM770-10 speed ring for a 36t SLX 9 speed and noticed no change in shifting performance.
You can always drop the front mech a mm or two if it's a problem, I'm currently running a M785 2x10 with 24 -36 rings.
Posted : 09/08/2013 8:06 pm
 mboy
Your front mech will be fine...
However your cranks will not. You'll need to swap them for a conventional triple, but ditch the outer and middle rings and put a middle of your choice on instead.
Posted : 09/08/2013 8:45 pm
dirtydog, you're running the same m785 double cranks as me. Is your 36t ring the SLX 9 spd you mention?
Posted : 09/08/2013 10:49 pm
No mate, I'm running triple M770 10 speed cranks with the M785 double specific mech, 24 - 36 rings and bash. The 36t is a 9 speed SLX middle ring and it works fine with my 10 speed setup.
I'm not sure what the issue with your crank is, Mboy?
Posted : 09/08/2013 11:21 pm
 mboy
The OP is running XT double cranks currently. Smallest "big" ring they can take is a 38T.
If he switches to conventional triple cranks such as you and I run, he can run whatever size middle chainring he likes down to a 32T.
Posted : 10/08/2013 7:25 pm
On an XT double the smallest is a 33t, otherwise the chain fouls the tabs in the outer position
Posted : 10/08/2013 7:39 pm
