is there one longer than 465mm?
yep, 470 & 490.
On one 'normal' and tapered monocoque are 470.
Kinesis IX is 490
Carbonzone (on ebay) is 490
Edit, wot they ^^^ said..
these are the carbonzone forks- one is taper steerer, the other is straight.
dont want [s]plastic[/s] carbon
thanks tho..
You might struggle then!
Look for an early Singular Swift fork? Steel and 485mm.
New ones are shorter. Give Sam a shout to see if he has any or knows of any?
Voodoo's zombie 500 fork. i guess the 500 bit refers to a to c?
http://voodoo-usa.com/bicycles/zombie500fork
seems that you would need someone in usa to order it for you...but might be available in uk someday? ๐
Ton - I have some 'heavy duty' 485mm a/c Swift forks which were designed just for you. I had a few cases of heavy/hard riding folks bending the original long ones so had some made with the same dimensions, but thicker walled tubing.
Soul Cycles Dillinger Fork: http://www.ridesoul.com/?page_id=29
A-C: 485mm
Currently standard QR dropouts but they're about to release a bolt through version and a carbon one is being tested this spring.
Oh yeah, $99 ๐
