29er's Survey:...
[Closed] 29er's Survey: stem angles - inverted giving 0 deg or angled up to the stars?
how we running our clown bikes these days?
Posted : 14/10/2010 2:55 pm
Short 30 degree rise stem on both, due a neck/wrist problem, to get the weight off my hands.
Posted : 14/10/2010 3:20 pm
100mm, 6 degree rise, on 2" risers, tried some fleegles but needed a high rise stem and it looked daft.
Posted : 14/10/2010 3:22 pm
100mm 17 degree rise with Fleegles
Posted : 14/10/2010 3:39 pm
100mm 0 degree with 600mm flat bars
Posted : 14/10/2010 3:55 pm
Currently running a 6 degree-rise 100mm stem with a low-rise wide bar. With no stackers. Running a stem up-side-down with low-risers just looks (and feels) plain wrong to me.
Position's not *far* off being perfect, but I'll soon be running a nought degree-rise 90mm stem.
Posted : 14/10/2010 3:56 pm
90mm 6 degree stem upside down (eg negative rise) with no spacers under it on an XL swift. I was thinking last night that it's still a bit high though - I reckon Swifts' head tubes are a bit too long. I don't know how people ride some of the setups I see - looks like you're on a vicar's bike with the bars up in the sky ๐Ÿ™‚ Each to their own, I guess...
Posted : 14/10/2010 3:57 pm
It depends.
When I was running a drop bar, I had a high-rise stem (120mm 45deg, IIRC). Now that I've got flipped Mary bars on there, it's a negative rise 90mm stem.
On the TD-1 I borrowed, it was a 70mm low-rise (6deg?). Other people on the same bike have different length stems.
If I had a 29er DH bike, it's have a very short/low stem. Like I have on my 26" bike, in fact.
Posted : 14/10/2010 3:58 pm
[img] http://images.fotopic.net/?iid=1fajr7&outx=600&noresize=1&nostamp=1 [/img]
Posted : 14/10/2010 4:11 pm
small ragley td-1 carnegie bars 50mm stem,, it's greaaaaaaaaaaaaat as Toni would say
Posted : 14/10/2010 6:30 pm
90mm 6 deg stem here with carbon risers on a Tallboy. I was thinking about flipping it this weekend to see what it was like, maybe flip and move up 2 spacers, its just a wee bit high right now. Interestingly my wife was having problems on her anthem with setup and i flipped the stem on that and it sorted them for her, much better position. Always worth fiddling with these things to see what works and what doesn't.
Posted : 14/10/2010 6:33 pm
 mboy
80mm 6 degree rise with 710mm flat bars. On an 18" On One (short head tube) with only 1 headset spacer (which was necessitated by the very short 175mm steerer on the Reba's I inherited).
Suits me ok, if anything I could probably run some 15-20mm rise bars instead of the flat bar, but I quite like the low and long stance on the 29er.
Posted : 14/10/2010 6:46 pm
100mm 0 degree stem with a a 10 degree sweep flat bar.
Posted : 14/10/2010 6:52 pm
Mid rise Easton ea70s a 6 degree stem at 90mm, and a few spacers!
Posted : 14/10/2010 8:13 pm
 JRTG
110mm 6 degree negative stem with 620mm bonty big sweep bars on rigid niner forks. How some of these bikes go round corners with such high front ends is a mystery to me......
Posted : 14/10/2010 8:23 pm
70mm 0 degree rise
Posted : 14/10/2010 8:41 pm
80mm 7 degree rise on both of mine, one with flat bars, one with risers (clerical collar just out of shot)
Posted : 14/10/2010 8:42 pm
when i had my Paragon, i had a 90mm -12deg stem and flat bars, and which ever big wheeler i get next year will probably be the same racy set up........
Posted : 14/10/2010 9:12 pm
i run a 90mm 5degree upside down, with 710mm flats like my bars low.
Posted : 14/10/2010 9:17 pm
-6 degree stem and flat bars.
Posted : 14/10/2010 9:21 pm
2 surlys...25mm spacers, 90mm 0 degree`s stems,2" riser bars- but i hate low bars though it suits some guys... ๐Ÿ˜ฎ
Posted : 14/10/2010 9:34 pm
A lot of people on STW, not just 29er owners, seem to run their bars far, far too high.
Posted : 14/10/2010 9:48 pm
 gee
6 deg 100mm stem inverted with a riser bar and 20mm of spacers.
Yes, I could remove the spacers and run it the right way up but then I'd have to cut the steerer and that makes the forks harder to sell on at the end of the season. Plus I prefer the look of an inverted stem as the line matches the top tube.
GB
Posted : 14/10/2010 9:56 pm
You big tart! ๐Ÿ™‚
Posted : 14/10/2010 10:01 pm
miketually - Member
A lot of people on STW, not just 29er owners, [s]seem to run their bars far, far too high.[/s] run their bars how they like and don't give a toss
fixed etc
Posted : 14/10/2010 10:02 pm
 thv3
80mm 0 degree rise and flat bars. Seems "right" for me, just now...........
Posted : 14/10/2010 10:04 pm
How can a bar be too high, within reason?
Posted : 14/10/2010 10:05 pm
110mm, zero rise stem, 5mm spacer, Element Nickel wide bars cut down a tad.
Posted : 14/10/2010 10:06 pm
Handlebar height it relative to saddle height. And should not be judged on the basis ofbar, stem and spacer combo!
Posted : 14/10/2010 11:11 pm
yeah...too high says who?, personly i dont want all the wieght on my wrists and i like to look around while riding not 3 feet in front ๐Ÿ˜ฎ
Posted : 14/10/2010 11:18 pm
That'll be me then.
[url= http://farm5.static.flickr.com/4130/5001272931_03794c7fbb.jp g" target="_blank">http://farm5.static.flickr.com/4130/5001272931_03794c7fbb.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/8805115@N04/5001272931/ ]Lynskey[/url] by [url= http://www.flickr.com/people/8805115@N04/ ]Vegan Graham[/url], on Flickr
I know it's wrong, but if it's the only way I can keep riding for 8 hours around Ashton Court tomorrow, it'll have to do.
Posted : 15/10/2010 2:05 am
Had a 115mm with 5degree rise, with carnegie bars (which do bring the nhands back a bit), but felt too far over the front on the steeps, so recently switched to a 70mm 0degree stem with 685mm flat bars. Feels very good.
Kev
Posted : 15/10/2010 5:33 am
 Sam
100, 5 deg rise, usually up, down if I'm feeling all racy.
For everyone that says they're too long, I've got someone else who says 'thank god you make em a decent length'. As they say, you can't please everyone! You'll be glad to hear the Pegasus does have a slightly lower, more race oriented geometry though Clubber.
Posted : 15/10/2010 7:33 am
too high says who?
Raising the bar height seems to be the default response to feeling uncomfortable on the bike and/or done to "improve handling". It's not always the correct response.
And it looks gash ๐Ÿ˜‰
Posted : 15/10/2010 9:39 am
90mm +6deg with low risers but have also run it 100mm +17deg with drops on but no pix
Posted : 15/10/2010 9:45 am
6 degree rise on its side at the botom of a box of parts in the spare room. Sam, how are you getting on with that latest batch?
No pressure...
Posted : 15/10/2010 9:49 am
Yeah, I know Sam but a 20mm shorter head tube (even 10mm!) could be spaced up but it's an arse to space down. Plus the TT clearance would be (admittedly very slightly) better - though I'm blessed enough for that not to be an issue ๐Ÿ™‚
Pegasus would be lovely but I think the cost of the resultant divorce would outweigh any benefits ๐Ÿ˜‰
Posted : 15/10/2010 12:02 pm
-10 degree/100mm stem & a flat, wide EA70
Getting the weight over the front makes world of difference to handling.
Posted : 15/10/2010 2:24 pm
