29er suspension for...
[Closed] 29er suspension fork for some who makes clydesdale look slim...
I'm just about to take the plunge and get a Solaris in XL
I'm 190 cm tall - and around 130 kgs but working on it
I need a recommendation of some forks so:
air sprung (easier to set up)
120mm travel
500 quid max - the near 300 quid , the happier I will be
Tapered steerer
On my current bikes I have been using revelations , which have stood up well
Should I be looking at 34 or 36 stantions because of my bulk
Any thoughts?
Posted : 11/06/2013 7:37 pm
I'm a carbon copy of you right down to bike choice. I bought the dual air revelations with tapered steerer from crc, if they've still got em I foresee zero issues.
Posted : 11/06/2013 7:49 pm
I was up near that weight for a while. My 100-130mm revs on my Soda held up fine. This was 26 though.
Now down near 100kg after a hard 9 months, and the fox fork on my Gyro 29er copes fine. It feels very stiff.
Lummox
Are they the 130 mm travel ones adjusted?
http://www.chainreactioncycles.com/Models.aspx?ModelID=94595
or these
http://www.chainreactioncycles.com/Models.aspx?ModelID=94595 <
Posted : 11/06/2013 7:57 pm
I'd get the revs at CRC if they're still cheap
Posted : 11/06/2013 8:09 pm
Think you've linked twice to the same forks, but yes that looks like them. I hasten to add I'm still waiting on the frame but my 26er revs haven't missed a beat and I've really given them some stick.
Internally adjustable via spacers (which were in the pack)
Posted : 11/06/2013 8:17 pm
i'm tempted by a pair of those revs to replace my 100mm rebas on my Carbon Cube hardtail,... i've got about 20mm worth of spacers, and a stem with rise, so get rid of those and it should pretty much offset the extra height of the fork shouldn't it...
it's a great bike, i'm just doing some stuff that is right on its limit at the moment and the 20mm bolt-thru would be lovely, as i'm QR at the moment.....eeesh new wheel too
would this be okay do you think?
Posted : 11/06/2013 8:25 pm
I doubt 120mm forks would work well on a carbon hardtail designed for 100mm? Slacker ha, slightly higher bb....and no warranty?
Posted : 11/06/2013 8:29 pm
I meant these
http://www.chainreactioncycles.com/Models.aspx?ModelID=94599
Posted : 11/06/2013 8:36 pm
Ah, nope mine are the cheaper ones but I'd imagine they would space down fine.
Posted : 11/06/2013 9:20 pm
