29er Plus Suspensio...
[Closed] 29er Plus Suspension, 120mm travel 🤷🏻‍♂️
Hi All
Sooo, I know the naysayers will tell me it shouldn’t be done...but ! I am after an after market fork for my surly Krampus, but I am struggling to find information on one that will reliably take 3 inch Maxxis Chronicle - and when I think I have found one, they are out of stock ! Does anyone have any reliable information on a fork with 120mm travel that would work ? Preferably something that is in stock somewhere too 😂
Posted : 28/06/2019 10:19 am
There's a 29+ Pike, but not that many around!
Posted : 28/06/2019 10:23 am
There is also the offering from Manitou, but I appear to be looking for hen’s teeth !!
Posted : 28/06/2019 10:29 am
I managed to squeeze a 3" Minion into a Fox 34... never rode with it, as at 120mm travel it jacked up the front end too much, but may yet try to reduce travel to 100mm as an alternative too rigid. Tyre cleared the arch no problem,...  I didn't try it at full compression to check it cleared the crown OK, but if you ran it firm, to avoid bottom out, it might work?
Posted : 28/06/2019 11:46 am
Aion35 29+
This is 29x3 Minion on 45mm id rim in 29 boost Suntour Aion35
The same applies to auron35 and durolux
Posted : 28/06/2019 12:03 pm
The current 29" Revelations and Pikes take a 29+ tyre. Here's my Stache with a 3.00 Chupacabra in there. There's more room than it looks in the photo, enough to comfortably fit a mudguard around (which is how it's set up now).
These replaced some Manitou Magnums. They have the advantage of having a much lower axle to crown than the Manitous - the Revs are 150mm and the axle to crown is only 10mm longer than the 110mm Manitous. They also perform a lot better.
Posted : 28/06/2019 12:18 pm
