29er flow rims and ...
[Closed] 29er flow rims and tyres aaaarrrrrrrrrgggggghhhhh
Got a pair of 29" hope hoops with flows and racing ralphs, today I had my first puncture and encountered the task of removing a tyre in the pizzing rain. I have not used tyre levers for years, having relied on chipps hands only method. So are there any tyres that can be got on/off flows without levers and the strength of hulk.
Not fussed what, as long as they are round and nobbly.
And no I dont want to go tubeless.
Ta in extreme anticipation.
Pete
Posted : 10/02/2013 3:41 pm
I gave up and went tubeless.
Posted : 10/02/2013 3:49 pm
Smorgasbords went on mine a piece of piss.
Posted : 10/02/2013 3:53 pm
Why have flows and not go tubeless??
Posted : 10/02/2013 3:56 pm
You're already on Flows, but don't want to run tubeless? ๐Ÿ˜•
Posted : 10/02/2013 3:57 pm
MAxxis Aspens seem quite a loose fit in general.
Ruben Scylla are the loosest i've ever seen/fitted though.
Posted : 10/02/2013 4:13 pm
Flows & not tubeless o_0
Posted : 10/02/2013 4:41 pm
 IA
As above, why not tubeless?
Also this +1:
(chunky monkey on the front though).
Posted : 10/02/2013 4:46 pm
Yeah, why did you buy Flows if you don't wanna go tubeless?
Posted : 10/02/2013 5:01 pm
Cos I wanted some tough wheels, would have much prefered mavic as in 26 mode I have always used 521/321, however the only offering from mavic is 719. Asked around for rim suggestions and all I got was Flows.
I am about to need a pair of 29 wheels for a sultan - rim recomendations welcome ๐Ÿ˜€
Posted : 10/02/2013 5:08 pm
Maybe he wanted a set of light ish, wide rims!
Posted : 10/02/2013 5:10 pm
Seems to me Hope need to add a bit of choice to rim options
Posted : 10/02/2013 5:12 pm
 ton
smorgasbord tyres here mate, easy on and offable for a big tough lad like me and thee.
oh and sell the flows and get some kris holm's or some rigida sputniks.
Posted : 10/02/2013 5:40 pm
Flows are good rims whether or not you want to go tubeless.
Posted : 10/02/2013 5:41 pm
Stans Flow work well on my Sultan.
Use the 'well' in the middle of the rim. Seriously - push the tyre back into there, work it down all the way around. Works very well and often overlooked by people. I was 'annoyed' until I worked out how to do it properly.
Posted : 10/02/2013 5:42 pm
They do Mavic and DT too.
Posted : 10/02/2013 5:45 pm
Seriously, if you'd been tubeless you wouldn't have had a puncture!!
Posted : 10/02/2013 7:34 pm
Smorgasbord went onto mine pretty easily, Chunky Monkey more difficult bu still doable without levers. Harder to get off mind.
Posted : 10/02/2013 7:36 pm
Are flows that much different to crests other than rim width because my racing Ralphs went on and off no problem. It's only tight if you don't pop it off the bead of the rim all the way around before trying to take it off.
Posted : 10/02/2013 7:46 pm
[i]Seriously, if you'd been tubeless you wouldn't have had a puncture!! [/i]
OP has Racing Ralph, they all puncture eventually
Posted : 10/02/2013 7:52 pm
 bigh
Some tyres are easy some are a pain in the rear. Rubber queens fell on for me, and go tubeless or you're wasting good rims.
If you do go tubeless, i found 1 inch duck tape far better than stans tape or the rubber strip with built in valves
Posted : 10/02/2013 7:54 pm
I've got the same set-up, but tubeless. Not had a puncture for 11 months now!
๐Ÿ˜‰
Posted : 10/02/2013 8:00 pm
