As title really?
Not very...
Fatbikes [i]are[/i] 29ers....
nononononono a 29er rim with a Fat tyre to make it MAHOOOOSIVE! say for example like the 3.5" 29er rubber I've got coming for a little project ๐
Like I said... tazzymtb leading the vanguard! It will indeed be "MAHOOOO...OSIVE" ๐
Nuff said. Never thought of it like that
or so heavy it sinks without trace ๐
Will it be a 36er
it'll come in around 32-33" It could be an expensive folly, but it's fun trying daft things and just now n then it's magic
What gyres are they tazzy? My estay bike has enough clearance to run them
Ade, I'll email you the details fella.
That would be good ade1963@aol.com Cheers
more info on the 29er 3.5 tyre your getting please
erm, isn't a 29er so called because the outside diameter of the tyre is approx 29" (the rim is only approx 24.5" in diameter). So if you put a 4" wide tyre on you'll have an OD of more like 31" or something.
my bigboy should arrive tomorrow, so I'll post some pics and dimensions when I get it fitted and find some lifting gear to pick the wheel up.
rumour has it there may be a 26" version available as well, so i'm lookin into it
did you get your tyre?
