29er disk brakes
[Closed] 29er disk brakes
[#1711093]
Same size as on the 26er or a size larger/smaller?
In my head I'm thinking the wheel is a larger lever so I need more torque from the disk brake to apply the same force at the ground?
Posted : 16/06/2010 5:10 pm
Bigger looks better on a big wheel but actually it don't make no difference - the brake is just there to convert kinetic energy into heat.
Posted : 16/06/2010 5:13 pm
tinas - bigger will be better for the reasons you suggest, whether it is necessary is another matter 🙂
Posted : 16/06/2010 5:18 pm
Given the wheel is 10% bigger ALL COMPONENTS must also be 10% bigger or it won't work.
Posted : 16/06/2010 5:51 pm
I run 180f 160r - works for me. But I'm a big chap.
Posted : 16/06/2010 5:54 pm
I take a larger stick to jam in the front wheel
205mm disc actually
Posted : 16/06/2010 6:30 pm
203 front and rear here, not sure there is a great deal of difference over 180s but I had them so I used them...
Posted : 16/06/2010 6:56 pm
160 front and rear here.
Posted : 16/06/2010 7:06 pm
180 / 180 here
Posted : 16/06/2010 11:46 pm
The bike weighs about the same and you weigh about the same, so the same mass is moving so you'll need about the same brakes to stop.
Posted : 17/06/2010 6:44 am
Agree with halfbee size of breaking power can only relate to the weight your trying to stop and the speed your going at. I suspect you'll see bigger rotors on 29'' because your larger gentleman will favour the big wheels.
I'm demo'ing a 29'' weekend after next, can't blooming wait!
Posted : 17/06/2010 7:38 am
