what else is there?
not that i can afford one, but other 29er fs frames which'll fit at LEAST 2.6" tyres please
Worth a look at Orange Stage 4, 5 and 6.
Not gone beyond 2.4in rear on my S6 but clearance seems very generous.
Salsa bucksaw😈
Banshee Phantom or Prime.
I don't think you are going to get that with a frame with chainstays going the conventional route, even with boost there isn't going to be enough room. I have a Trek Slash, which makes full use of the boost width at the bb and has slim chainstays, and it will probably just fit a 2.6 29" tyre, but on a dry trails only basis.
geometron g13.
fits specalised 2.6 29"
It might depend which 2.6in tyres as well.
ie. Spesh ones measure about 2.45in IRL.
I'm deffy in the dry trails only bracket, luckily for me.
current frame (26er) fits 275x2.6 nobby nic in the back, so that's already quite good, but wouldn't be an option in mud i reckon
so phantom and prime, is that by sticking on the275 drop outs from spitfire etc?
damn, prime back on top of the list then
my stumpy is running 2.6 marys
but my mate turned up with a full stach on wednesday. lighter and faster than my carbon stumpy!!! with big rubber.
Can get a Maxxis 2.5 or a Butcher 2.6 in the back of a 29er Enduro with the boost back end and still plenty of room.
Can get a 2.6 butcher into my whyte S-150. Not acres of room but it's not clagged up at all this winter.
lighter than your carbon stumpy?
i thought they weighed about 15 kilos?
Stumpy 2019 one will take 29 X 2.6 and there's still 10 mm clearance per side or 27.5 X 3.0
Salsa Deadwood, but good luck getting one. Takes 29+.
The stumpy is lumpy as the FS Stache is 34Lbs with tubes mind it rides great you feel your on a bike with way more travel.
Maybe Scott Genius?
The 29er will take decent tyres and you can go 27.5+.
My test bike arrives tomorrow.
Norco Fluid is 2.6. Comes with Forekasters.
I have a 29×3 carbon fattie and was considering a full stache to replace it. Fluid has good geo and is cheaper so I get to keep both.
trek fuel might do, I'll throw one in the back when i get to work. it'll fit in the fork though
yeh they do fit 2.8 apparently.
wish the smuggler took bigger'n 2.4"...
