27.5 RS Pike solo a...
[Closed] 27.5 RS Pike solo air 140mm to 160mm?
Hi, first time poster here. As the title says, can a RS Pike solo air (2016) with 140mm travel be adjusted to 160mm? Is it just a matter of a new air shaft?
I know you can adjust from 150mm, but not sure if 140mm to 160mm is possible.
Thanks
Posted : 09/08/2018 6:27 pm
Yes just a change of air shaft. I believe 160mm is the max on the Pike too:
https://www.tftuned.com/35mm-solo-air-a1-pikeyarilyrik-air-shaft/p3411
Or if you don't have a Luftkappe then get the new 2019 debonair air shaft:
https://www.tftuned.com/debonair-air-spring-upgrade-kits-pike-yari-lyrik/p3412
Posted : 09/08/2018 10:53 pm
