My current crest/superstar rim aren't up to the job any longer,I've had them true'd a few time and just had them rebuilt but within 100 miles I've got a load of loose spokes again.
So I'm looking a getting a stronger set to replace them.
Is there any thing else I should be looking at apart from these Superstar rims
[url= http://www.superstarcomponents.com/en/tech-4-tubeless-ready-wheelset-ex23.htm ]http://www.superstarcomponents.com/en/tech-4-tubeless-ready-wheelset-ex23.htm[/url]
Don't realy want to spend more than a couple of hundred quid.
cheers
I have some Superstar wheels on my road bike and would buy from them again.
What's your theory for the current wheels having given up?
Surely spokes coming loose means one or more weren't tightened correctly? or you've got a weakened rim which is flexing and working the nipples loose. Why would your rim have become weaker? is it cracked?
Just curious 😀
If your nips aren't brass that could be the issue?
I'm guessing my rim is weakened as it won't stay true for any length of time and I was snapping a spoke every other ride.
I was hoping a rebuild with new spokes would solve the problem but now I'm suffering from several loose spokes after every ride.
My plan was to replace them with something a bit more beefy.
Not sure what my nipples are made of to be honest!
What about buying 2 arch or flow rims and getting a bike shop to build them onto your current hubs. You might not need new spokes, if so should be about £200 ( 110-120 for the rims ans the rest for labour)
I did think about just fitting a Flow on the rear but I can't find any in 26" in white (to match my front Crest)
I'm in the same position and will be getting some DT Swiss EX471 and having them built onto my hubs, should be less than £150 all in. Can't find a bad word about the rims, WC DHers use them and they're lighter and cheaper than the competition
I not sure it's cost effective to rebuild my old superstar switch hubs with new rims v new wheels
That depends if your hubs are in good nick, if they are no reason why it shouldnt be (depends on how much you value a certain rim as well)
Yeah, If you're just going for those rims anyway then get the wheels, but otherwise you could invest the same cash into some nicer rims.
I'm rebuilding onto my hubs as I have the 40t Pro II evos and have just replaced all the bearings in them and have another bearing kit on standby, plus the wheelset with the EX471 rims is about £600!
hubs are OK but I'm not sure there's another winter left in the bearings
The Pacenti's in their clearance sale look a good buy with a choice of rims widths.
I bought a set of those wheels OP when they had the offer on for £160...... And I tell you what they're bloody great value, well built and no deflection in them unlike the stock wheels that came on my Boardman pro that had been rebuilt once but then freehub died big time.
I am just unde 18 stone with my riding kit and 3 litre bladder riding them on the hardtail as hard as I can......
I certainly can't justify buying Hope options when for the money you can run these!
A bit over your budget but the carbon AMs on offer at £300 are a steal
