2.4 tyre on the rea...
[Closed] 2.4 tyre on the rear 2.2 on the front, tell me why I shouldn't?
My rear tyre gets far more grief than my front. I can't remember ever pinch flatting a front tyre and as I run tubeless/stans fluid in both, they are equally immune to thorns. So unconventionally I am thinking of going 2.2 on the front 2.4 on the back. I don't want to go 2.4 all round as A. they are heavier and B. I would have to buy another 2.4.
I run Continental Trail Kings. I put my calipers on both tyre sizes (inflated on my Flow EX rims). The 2.4s are less than 3mm wider, but about 7mm deeper. So grip-wise the two sizes must be more or less identical, but the larger one gives you 7mm more air to go through before you mash the rim. The wise (and not so wise) thoughts of the forum appreciated.
Posted : 24/08/2015 10:54 am
I run more pressure in the rear, so even with matching tyres I have more air to squish before rock meets rim.
Also the wider tyre with more volume should grip better- I'd rather the front of my bike don't wash out before the rear.
Posted : 24/08/2015 11:01 am
give it a go, if it works for you then it works.
Posted : 24/08/2015 11:07 am
Not a problem on in my eyes. When do you ever see a motorbike with a fatter front tyre than back
Posted : 24/08/2015 11:08 am
That may be something to do with having 100 horsepower rather than 0.25 horsepower amongst other things.
I too am more concerned with front wheel lateral grip on a bicycle.
Posted : 24/08/2015 11:24 am
I'm about to do exactly the same on my hardtail. To quote STW Barney, 'the front is writing cheques that the back can't cash'
Posted : 24/08/2015 11:47 am
as above i know which one i'd want to wash out first, and it isnt the front
why not just put more air in the rear?
Posted : 24/08/2015 11:53 am
Grip decreases with increased pressure.
Posted : 24/08/2015 11:56 am
Hmmmn, am doing that more or less at the moment - have a 2.4 NN on the back and a 2.3 Hutchinson Squale on the front. Schwalbe is a 'big' 2.4, whereas the Hutchinson is pretty much standard size.
I haven't been too happy with it to be honest and will be putting my Michelin Gripr on for the winter and then going back to Hans Dampf come next summer. The front has wash out a few times on me, I miss the extra grip of a big tyre.
Posted : 24/08/2015 12:09 pm
