2.3" inner tub...
[Closed] 2.3" inner tube in 2.4" tyres?
8 Users
Would you use a 1.5 to 2.3 inch tube in a 2.4" High Roller?
It seems that inner tubes have a cross over around the 2.3" mark, ie before you move up to a much bigger DH and heavier type tube.
Plus, I'm looking for some deals on 10 packs of tubes if anyone knows of any?
cheers
Posted : 02/04/2012 9:46 am
it'll be fine.
bontrager do a 2.5" xc tube
Posted : 02/04/2012 9:47 am
I run a Bonty 2.5" DH tube in my 3.8" tyres. It's fine.
 GW
I'm actually running a 24" tube in a 26" tyre just now.
You do realise butyl tubes stretch?
Posted : 02/04/2012 9:51 am
It'll be fine but CRC have deals on tubes in this overlap. Ten 2.1-2.6 tubes for £24.99 [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=78326 ]H E R E![/url]
I use these tubes, they're great. Butyl which is better than standard rubber but they do have slightly unattractive green caps. £2.49 a tube with postage is not to be sniffed at!
Let's blow sh*t up!
Posted : 02/04/2012 9:54 am
It'll be fine. Although I tend to fine using a smaller tube in a bigger volume tyre can lead to more punctures, as the rubber is thinner to fill the larger volume tyre.
Posted : 02/04/2012 9:55 am
If it explodes (which it almost certainly will) it'll rip you in half. If you're lucky.
Posted : 02/04/2012 9:58 am
2.1" in a 2.4" tyre here no probs
Posted : 02/04/2012 10:20 am
thanks guys, and it's not like most 2.4" tyres measure up to that size anyway..
Posted : 02/04/2012 10:44 am
