22T single ring set...
[Closed] 22T single ring set up?
[#5636823]
Please excuse me if this is a stupid question, but does anyone run a 22 tooth single run setup?
Posted : 26/10/2013 1:08 pm
No. How slow would that be unless you have a one tooth cassette?
Posted : 26/10/2013 1:13 pm
This looks more like 24, and there's a reason why it's so low and still usable:
http://singletrackworld.com/forum/topic/18-bikes-pinion-bike
Trials riders might get down to 22T at the front?
Why do you want to know?
Posted : 26/10/2013 1:51 pm
Because I live on a really steep hill with very technical climbs. I'd love the simplicity and weight of a single ring setup, but I really need my 22/36 lowest gear. On the other hand I rarely if ever use more than 5th gear with the middle ring.
Posted : 26/10/2013 4:07 pm
Well, it's easy to try it out innit? Just don't shift up from the granny for a week or so and see how you get on.
I'd say it's a bit low personally - I never once found 22/36 useful when I was still using a granny and I think you'll be surprised how fast you get fitter once you eliminate the possibility of shifting down a gear. I'd do 28t up front if I lived anywhere really steep and technical (running 32t now on not-so-steep-or-technical terrain and my noodle legs do fine).
I also think you might have a hard time setting up a 22t single ring with a decent chain line (which is essential because if you can't use the entire cassette then it's going to be [i]really[/i] limiting IMO). Single specifik rings are available in 28t (and maybe even 26t, but surely no smaller) for spidereless SRAM cranks, for example.
Posted : 26/10/2013 4:30 pm
I'm sure I asked before about running 22-11 and was told there was a reason why it wasn't common but can't remember it...
Posted : 26/10/2013 7:07 pm
I ran a 24T on a 29er for a while (so roughly equivalent gearing to a 27t on a 26er) and it was too low, even on the steepest stuff I rarely used 1st gear.
Posted : 26/10/2013 7:13 pm
You UH lot are an odd bunch. Do people really actually enjoy gurning up long steep climbs?
Fair enough if it's for some decent dh singletrack.
Have you thought about getting a group ride together and doing some downlift days at bpw?
Posted : 26/10/2013 8:33 pm
Not sure what your point is? Should folk walk up climbs? Or avoid them altogether 😕
Posted : 26/10/2013 8:38 pm
Yes.
Posted : 26/10/2013 8:40 pm
Walking would be quicker than with that gearing..
Posted : 26/10/2013 8:42 pm
 cp
Oh yes 🙂 Went for a post work road ride the other night purposefully filling it with climbs. Love em!
Posted : 26/10/2013 8:47 pm
 ton
26 front
12/36 rear
perfect combo imho
Posted : 26/10/2013 8:50 pm
used to run 22t single on my trials bike. it's too low for general riding IMO.
Posted : 26/10/2013 9:54 pm
i have used 24/36/46 with a road cassette (12-23) and tbh it was fine.
dunno if this helps.
it did mean i used the granny slightly more often, and i was reasonably fit at the time.
Posted : 26/10/2013 10:03 pm
