20mm Rock-Shox Axle...
[Closed] 20mm Rock-Shox Axle not staying closed?
I'm running a 20mm rock shox axle on my new bike and after 8 week the quick release lever now has suddenly no resistance so doesn't clip in anymore??
i used it a lot over the weekend and the screw in axle worked loose as well so it does more then looks!
Any help much appreciated!
Posted : 14/03/2011 6:17 pm
There's a 2.5mm (I think) allen headed bolt under the head of the lever that adjusts the tension needed to close the QR. Try winding it in a little and it should tighten up the lever again. Don't try and alter the position of the lever relative to the fork once you've clamped it up - get the orientation right, then clamp it, or it'll loosen off. I'm assuming it's a current Maxle Lite btw, earlier Maxles work slightly differently.
Posted : 14/03/2011 6:20 pm
