20mm bolt thru + 13...
[Closed] 20mm bolt thru + 135qr wheel recommendation
4 Users
 Ogg
I want a new 29er wheelset front's 20mm and rear is "standard" 135qr both of which these days seems to be a bit obscure!
Under £400 preferably and tubeless obviously...
In the past I would have gone for stans on hope most likely arch rims.
Posted : 22/05/2018 6:59 pm
Other'n boost vs non boost, most quality 142 wheels will adapt to QR, might mean buying adaptors though.
Posted : 22/05/2018 7:40 pm
Hope.
135mm rear comes with QR and 142mm end caps as standard. Fronts come with QR, 15mm, or 20mm as options.
Shop about out and you can pick them up for £360 ish.
Posted : 22/05/2018 8:18 pm
 Ogg
Are the hope rims any good? I'd heard they weren't as good as the stans rims for tubeless?
Posted : 22/05/2018 8:56 pm
The Hope rims are excellent.
Easy to tubeless, the Enduro rims have taken my abuse as a clumsy, no-talent, smash through everything, fattened lump. Now got a set of W35, but not ridden them in anger yet.
My experience of Stans? Soft cheese, over priced, rubbish.
Posted : 22/05/2018 11:40 pm
Hope rims are fine for tubeless- but a wee bit overweight for what you get compared to the best from DT and WTB, and they don't have as wide a range. Good option though
If you're buying into an old standard it always makes sense to look for used stuff- in fact top end kit depreciates fastest as it becomes "obsolete". Basically, you can turn mtb industry bullshit to your own advantage
Posted : 23/05/2018 12:36 am
Buy a 2nd set of Hopes and you can get adapters to suit on here or elsewhere for around a tenner or less.
Posted : 23/05/2018 9:19 am
