Hi
Does anyone know if the fork on a Trek Farley 5 is FDS or RDS. Wanting to order Hope hubs - the QR front comes on two options (Front Disk Spacing or Rear Disk Spacing)
Posted : 30/04/2016 8:54 pm
I believe the Farley 5 is FDS. There's just over 10mm from the disc mounting face to the inside of the dropout.
Posted : 30/04/2016 9:23 pm
Cheers Mate. I ended up ordering both from CRC. Stocks were low... I'll send back the wrong one... I'll also confirm which type it is.
Posted : 01/05/2016 12:18 am
Are you keeping the stock fork? If you are changing the hub to fit a Bluto, then it will be FDS.
Posted : 04/05/2016 10:20 pm
Hubs arrived this morning. FDS it is. No plans to change the fork at present - that could change though.
Posted : 05/05/2016 9:48 am
